Thread: Umbrella Too Big??
    Umbrella Too Big??
    Have a umbrella sleeve in the tanning ledge. The umbrella I bought doesn't fit. The umbrella is too big. Instead of me buying another umbrella I have heard there is a solution to make this umbrella fit. Any ideas?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Umbrella Too Big??
    That would involve making the pole smaller, and unless it's wood that won't work. Even if it is wood, I'd probably just take it back and get a smaller one!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I was going to suggest liberal amounts of KY....but I guess taking it back works too.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
