Results 1 to 7 of 7
Thread: Sta-rite SR400NA
    Mar 2014
    Newport Beach, CA.
    8
    Sta-rite SR400NA
    It has been taking about 3.5-4 hours to bring my spa up to temperature (102 deg.).
    I had my pool maintenance guy look at the heater. He checked the sensors and they appear to be fine.
    What we noticed is that the heater goes on fine and the "Heating" red LED lights up, but then after anywhere from 10 mins. to much more time the "Service Heater" red LED lights up. However, my maintenance guy says that the unit should typically show a code on the heater that indicates what is wrong and why the "Service Heater" LED has come on. This is not happening.
    Any idea what could be wrong with the unit? It is about 8-9 years old.
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    Re: Sta-rite SR400NA
    Did they look at the board under the top of the unit to see if an LED's were lit up? If not, that is what needs to be done.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2014
    Newport Beach, CA.
    8
    Yes...Any other ideas on what could be wrong with the unit?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Have your guy check the thermostatic by-pass. Look for (any) corrosion.
    Factory Warranty Station for:
    Mar 2014
    Newport Beach, CA.
    8
    Quote Originally Posted by Pool Clown View Post
    Looks like it is the thermal regulator. THX
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by tminasian View Post
    Thermal regulator, thermostatic bypass, same thing, sorry for the confusion.
    Mar 2014
    Newport Beach, CA.
    8
    Thanks for your expertise...really appreciate your support.
