Results 1 to 11 of 11
Thread: freshwater silver ion system vs. other santizer system
    Mar 2012
    wood-ridge,nj
    11
    hello everyone,
    i just bought a hot spings relay spa 4 weeks ago. im trying to understand this freshwater ion system, and so far im not happy. my last spa i used baquspa products with the ozonator and never had problems. so far with system, im having cloudy water , foaming and low readings of chlorine. from what im told, this is basically a chlorine free system, so chlorine will not register on the test strips. so im discusing this with the salesperson (and owner), and im telling them how can my spa be clean without chlorine. they insist, between the ion silver cartridge, the ozone, the enhanced shock and the mps chlorine free, this system works.
    now i ask you great people of this forum, should i stay with this new system, or should i drain the tub and start over and go back to baquaspa.
    thanks ,rich
    spa is 360 gallons
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: freshwater silver ion system vs. other santizer system
    Personally, if it were my spa, I'd drain, thoroughly clean, refill and use the TFPC (Trouble Free Pool Care) methods taught here.
    Several of the experts here can tell you about the potential problems with the silver ion and baquasil (baquaspa) systems.
    Using chlorine isn't a problem in a spa, unless you or someone that uses the spa is sensitive to it.
    It is possible to run a spa with silver ions, ozone, and MPS. I don't actually know how to do that, and we don't have a tutorial on the site about how to do it, but it is possible.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    When I got my hot tub I started with Instant Ions (copper/zinc**, where you measure copper levels) which in fairness did work fine, but juggling chlorine/MPS to oxidize bather waste along with maintaining copper levels for the Instant Ions seemed like more work than necessary. The copper/zinc ions also didn't seem to do much for things like mosquito larvae, although I won't know until next summer how well chlorine works.
    I switched to the TFPC methods (using dichlor/bleach rather than adding stabilizer then bleach, but I think that's still consistent with TFPC practices) and am very happy with the results. Easy for me, nice clean water for the tub and my guests. The nice thing about chlorine is that it takes care of everything -- bacteria, algae plus oxidizing bather waste etc...
    ** AFAICS there are two different products on the market from different vendors, both called "Instant Ions". One seems to be copper/zinc/silver, the other (which I have) seems to be copper/zinc only.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Dec 2013
    Temecula - Southern California
    26
    I think it should be possible to maintain a clean and sanitary pool using the system you describe. My main concern would be with the silver. I see 2 issues. The first is that silver can cause stains, these should be removable on a non-porous surface, but some surfaces can be almost impossible to clean. The second is that silver is rated as a hazardous substance, so if you want to drain the spa you would need to check with your local water authority to see if the silver levels are acceptable for discharge into the sewer system.
    20k gal, IG gunnite plaster + spa, 2 HP Whisperflo pump, Pentair 520 sq ft catridge filter
    Pentair Min Max NT heater. Intelli-touch i5 controller, Ultrapure ozone (currently disabled), Rainbow 320 chlorinator
    Small water feature, Water slide. Poolvergnuegen 2WD suction cleaner.
    Mar 2012
    wood-ridge,nj
    11
    thanks guys. i think the method im using now is a pain in the a**. i will be switching methods after the next time i drain the tub
    Mar 2012
    wood-ridge,nj
    11
    check this out. so i go back to the dealer yesterday, and i go to buy chlorine, and he wouldnt sell it to me. he said i dont need it with the method im using. i asked him what to do after i have a heavy bather load. he said to use more mps and oxidizer shock. does this sound right to you guys? now im afraid to switch sanitizing methods on next refill, fearing i might mess something up
    Smykowski's Avatar
    Sep 2011
    3,065
    I think that dealer just lost your business.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Not at all. MPS doesn't sanitize, it only oxidizes Combine Chloramines (which get "burned off" by the sun and FC anyways under normal circumstances). He's wrong and trying to sell you expensive MPS. Don't be afraid to switch on your next fill!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Silver + MPS + Ozone can be an effective sanitizer at hot tub temperatures. In cases where that can't keep up and the water gets cloudy, it is common to add chlorine. The simplest thing to do is use household bleach (unscented/regular) as your chlorine source, since it is easy to get and use.
    Mar 2012
    wood-ridge,nj
    11
    thanks for the advice jasonlion
