Thread: Pump timing
    May 2013
    Missouri
    53
    Pump timing
    I purchased a mechanical timer that can have up to 12 on/off cycles. I read in pool school that even 4 hours daily can be enough but I am a clean freak and I can't stand stuff floating on top of my pool.
    Last year we ran the pump 24/7 because that's what all our neighbors do and that's what the pool store recommended when we were shopping for pools.
    I am pondering going to 12 hours total and then decreasing as I can tolerate. My question is, does anyone else run for a couple hours and then off for a couple hours? How is that working for the people that do?
    I consider myself to be a pool maintenance toddler rather than an infant now because this will be my second summer! I always appreciate any guidance on issues that I may not have enough insight on, so don't hold back! Thanks in advance.
    June 2013 24 x 52 Sharkline Heritage AGP (13,500 gal), 2 speed 1 hp pump, 150 lb filter(?), TF-100 test kit
    My first pool ever, pool school student with lots of questions
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Pump timing
    I run mine 6-8 hrs a day on two cycles. Sometimes 3 cycles. It's on a timer with preset on/ off stops. Depends on how much skimming I need. 24/7 is wayyy overkill. Like you suggested start at 10-12 hrs and then back it down till you don't like what you see and take it back up an hour. It's something you have to play with as every pool is different. 😎
    Jeff
    Re: Pump timing
    Running the pump for several short periods spread around the clock is ideal. The ideal is to run just long enough for the skimmers to pick up most of the debris, perhaps half an hour, and then do that once every three or four hours.
