Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Thinking about Active Chlorine
    Jul 2012
    Saugerties, NY
    447
    So if I understand it correctly, the concept of Active Chlorine refers to the portion of FC that is actively sanitizing. So when we take a measurement of FC, we get a number, part of which is tied up with CYA, and not actively killing algae and pathogens. The remaining portion is the Active Chlorine. The amount of Active Chlorine is dependent on the FC level and CYA.
    I've been thinking about this concept, and I'm curious if there is a noticeable difference in waters with higher Active Chlorine levels and lower Active Chlorine levels. Would there be a stronger chlorine odor with higher Active Chlorine? Will this water create the characteristics typically associated with "High Chlorine"?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Aug 2010
    Dallas, TX
    4,052
    Re: Thinking about Active Chlorine
    Typically, chlorine smell only occurs in a pool where CCs are present.
    What are the characteristics of high chlorine?
    38,520
    The higher the active chlorine level, the more damage to skin, hair, suits, etc. If I am in a public pool after getting out my skin often feels very dry and hair is frizzy. This in not observed as much in my own pool.
    Also, for a frequent swimmer, a swim suit may only last a few months in a public indoor unstabilized pool, but could last years if the water was maintained by our recommendations.
    Did you see my other posts about this table today which raise this question?
    http://richardfalk.home.comcast.net/.../pool/HOCl.htm
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by RobbieH View Post
    The characteristics I had in mind were along the lines of what Jbizzle hit on. The bleaching power, and the things people usually blame on high chlorine, even though it isn't always chlorine related.
    As for smell, Chloramines are usually responsible for the chlorine odor under normal circumstances, but when you add a lot of chlorine to a pool, you will smell it. For that matter, take a whif of liquid chlorine. There is no doubt that there is a smell.
    I'm not necessarily referring to normal situations, but thinking along the lines of a hypothetical experiment. Maybe an example where there are two identical pools, but one has FC=30, but CYA=90 and the other with FC=30 and CYA =20. The same FC, but with different CYA levels, the Active Chlorine levels would be very different.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Aug 2010
    Dallas, TX
    4,052
    I should have said chlorine smell in a properly balanced pool will be from CCs. Even at SLAM level, I don't smell chlorine in my pool.
    I realize the bottle smells, but I hope nobody is keeping their pool at 8.25%.
    Jul 2012
    Saugerties, NY
    447
    What you describe is along the lines of what I was hoping for. I have been thinking about using this concept as a teaching/training tool.
    Maybe mix up two batches of water in buckets, both with the same FC, but different CYA levels. Then have students guess which has "high chlorine".
    Possibly take it a step farther to add a little bit more shock value, where a lower FC level (maybe 8ppm) with very low CYA (maybe 0ppm) would appear to have "high chlorine" while the other sample with higher FC (maybe 20ppm) and much higher CYA (maybe 100ppm) would appear to be OK.
    Then you could test the FC in each and see that the bucket with the lower FC level appears to have "high chlorine".
    As for the table, I've seen that in the past. In this case I'm more concerned with the types of things the average person could pick up on, like odor, itchy dry skin, frizzy hair, etc. However, I came up with a question when I looked at it. Why do we see less than 50ppm Active Chlorine when FC is at 100ppm? Where does the other half go?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Jul 2012
    Saugerties, NY
    447
    I agree, you shouldn't typically be able to smell it. I have however, been in situations where due to the nature of a weekly maintenance schedule, it was necessary to bring FC way up, knowing it was going to fall back down quickly (usually in a swamp situation). At those higher levels, the smell becomes pretty obvious. But again, these aren't normal circumstances, and I certainly don't recommend doing this on a regular basis.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Chlorine actually has three forms (that we care about in pools): hypochlorous acid (HOCl), hypochlorite ion (OCl−), and bound to CYA. Only the hypochlorous acid is "active" chlorine.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Welllllllll.......even at 50 or 60 cya my pool loses 4 ppm daily in the Texas heat. So I take it to 8 to KEEP 4 ppm minimum in at all times.
    I take it back to 8 before a party too.
    Mar 2007
    San Rafael, CA USA
    12,082
    The hypochlorous acid is a faster disinfecting agent than hypochlorite ion by at least a factor of 20 because cells have negatively charged surfaces so tend to repel negatively charge hypochlorite ion, but for oxidizing power hypochlorite ion is sometimes the active agent. It depends on the molecule getting oxidized. Some get substitution or oxidation reactions from hypochlorous acid and others by hypochlorite ion and others by both. Usually the pH dependence gives away which is the oxidizing agent.
    As for smell, hypochlorous acid does outgas from the pool (and does so more than chlorine gas itself at normal pool pH) so at higher active chlorine levels you can faintly smell it especially if you churn up the water to increase aeration. This is most noticeable in spas due to the higher water temperature which not only increases the rate of outgassing directly but also increases the active chlorine level at the same FC/CYA ratio (more hypochlorous acid is unbound from CYA at hotter temperatures). It's true that the chloramines are more volatile so smell more than chlorine, but chlorine does faintly smell.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    I do get a faint "bleach smell" when opening the cover of my hot tub (at, say, FC=5, CYA = 30-ish and CC=0-ish), but it's a lot weaker than the smell in the laundry room after using bleach in the washing machine.
    And no, I don't normally use pool chlorine in the washer, just that one time and I diluted it 50/50 before pouring it in
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Mar 2007
    San Rafael, CA USA
    12,082
    Just FYI, the recommended levels of bleach to be used in washing machines is 1/2 cup per load and a washing machine load uses 23 gallons for a standard machine (15 gallons for ENERGY STAR certified), but that's multiple fill/drain only one of which would use the chlorine bleach. So let's conservatively use half so 12 gallons where 1/2 cup of 6% bleach would be 161 ppm FC (with the newer more concentrated 8.25% bleach it would be 221 ppm FC). Though there is no CYA in the water, the pH rises significantly to close to 8.6 so the hypochlorous acid concentration is equivalent to around 21 ppm FC at pH 7.5.
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by chem geek View Post
    Does this make the assumption of no CYA present (as would be expected in a washing machine)? 21ppm with no CYA is screaming high. Thanks for this chem geek. It really paints a good picture of how far apart pool water and washing machine concentrations are.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Quote Originally Posted by TreeFiter View Post
    Yes, that is a very high chlorine concentration. However, the other factor is the total contact time, which in a washer will be fairly brief.
    Therefore, the higher values are needed to work in the short amount of time the chlorine has to work. How much is actually needed depends on what you're trying to achieve, such as disinfection etc.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    There is barely a detectable odor of Chlorine from a freshly opened Bleach container IMO. You can hardly smell it.
    Essential Links:
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by Brushpup View Post
    I suppose its the kind of thing that would depend on a person's sensitivity to the odor.
    TreeFiter
    Pool Technician
    Saugerties, NY
    bridgman's Avatar
    Mar 2014
    461
    The smell in the laundry room is much stronger after washing with bleach is much stronger than the smell of a freshly opened bottle of bleach. I'm trying to resist the urge to capture the drain water from the washing machine and test the CC level.
    The bleach smell in the hot tub is less than the smell from a bleach bottle, although not *that* much less because the water is warm and there's a lot of surface area that is covered up most of the time and the smell gets saved up until you remove the cover
    In a spa, unlike a pool, CC is fairly common. Even if the CC level in the water has gone down to zero, volatile CC that has outgassed can still be trapped under the cover to amuse entertain surprise you when you open the cover.
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by bridgman View Post
    This is something I hadn't really thought about. The Chlorine used in laundry is there to do a job. By doing that job, a portion of it might be converted to CCs. I would be curious as well about the final CC levels in a load of laundry.
    Does anybody care to refresh my memory on what specifically causes FC to convert to CCs? Isn't it related to the way it reacts with undesireables in the water?
    I think I also made the assumption that by adding significant amounts of chlorine while shocking a pool, I would only be dealing with FC, but if I'm shocking the pool, there is going to be plenty of stuff in the water for that FC to start working on. I could be smelling CCs being generated rapidly from the newly introduced FC.
    TreeFiter
    Pool Technician
    Saugerties, NY
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you decide to do that, you will need to order a refill of FC reagents pretty soon.
    Essential Links:
