Results 1 to 14 of 14
Thread: Hayward S244T Sand Filter
    Mar 2014
    Chesapeake, VA
    74
    Question Hayward S244T Sand Filter
    Been lurking around local Craigslist looking for a Hayward Sand Filter, ran across one for less than $100, guy says he switched from Sand to DE. it is 5-6 years old, anything I should be leery of when going after this?
    Things to look at? I know I can get replacement parts locally if need be.
    Thoughts?
    Dave Graham
    6,000 Gallon 16' x 4' Intex Round Ultra Frame
    Hayward S244-T Sand Filter, Intex SWG, Hayward SF1593 1.5hp Pump, Hayward Thru-Wall Skimmer
    38,396
    Re: Hayward S244T Sand Filter
    Ask if it was moved with sand in it? How they removed the sand?
    Assuming it is empty, examine all the laterals inside as they are easy to damage if they man-handled it.
    Does it come with a backwash or multi-valve as well?
    Mar 2014
    Chesapeake, VA
    74
    yes it has the Multi-valve on it. I will inquire with the owner if it still retains sand. he did indicate it would need the 300# to make it work, so I assume it would be empty.
    Dave Graham
    Mar 2014
    Chesapeake, VA
    74
    One more dumb question on this topic (sort of) all the plumbing for it. should I run 2" SCH 40 or 1.5" SCH 40?
    Dave Graham
    38,396
    Usually better to use 2" on the equipment pad due to all the turn fittings that add head loss and lower flow rate. Although at lower flow rates with a small pump, it likely does not make much difference at all.
    Mar 2014
    Chesapeake, VA
    74
    when you talk about the flow rates, with my little 6k pool. with the 1.5hp pump I would be better doing 2" and reduce down to 1.5 when needed?
    Dave Graham
    38,396
    I was thinking a 1.5HP pump on a little pool ... flow rate does not matter (you will have PLENTY) and likely 1.5" is enough.
    My 18k pool only had a single 1.5" suction and return line.
    Mar 2014
    Chesapeake, VA
    74
    Ok gave up on the dweeb from Craigslist. I tried to contact him late Friday evening and no answers. contacted him Saturday he said he would get back to me, told him when i talked to him at lunch on Friday that I was interested in his sand filter. he got back to me late afternoon Saturday and stated he had a guy come by that morning and he had sold it.
    Oh well, I just got the 244 from Amazon for like $289 and some change + tax made it short of $300. not bad for a $500+ sand filter.
    It holds 300# of sand. One question, once I get this thing filled up, how do I move it, could I put it on a 2 wheel cart and shuttle it around?
    Plus now with that guy from Craigslist, he works in the pool industry, since he sold the one I was looking for, he said he had a newer version. Now I am starting to think, that maybe some of his customers switched out/upgraded and he had the old filters and was selling them for his own good.
    Dave Graham
    38,396
    You should not move it once it has sand in it or you are asking for the delicate internal components to break.
    Mar 2014
    Chesapeake, VA
    74
    ok, since I don't see me rotating my pool this year/season throw the sand into it and utilize the beauty of Hayward products
    I should have just went this route to begin with, got the 1 year warranty from Hayward, and if it has any issues just contact them. oh btw the guy said on the 'newer' filter, he would have to get some parts for it. so I am so done with him.
    Dave Graham
    Mar 2014
    Chesapeake, VA
    74
    ok new filter came in yesterday, talk about quick service, estimated delivery date was next week. I am going to start plumbing it in the next couple of days and get this thing running. was a little bit bigger than what I expected, but this is a great thing. Which means my surface area in the filter will keep me from having to do backwashes for my pool..
    Thanks TFP for the help.
    Dave Graham
    Mar 2014
    Chesapeake, VA
    74
    Greetings again to my friends of TFP. Just installed the S244 and wow, what a difference. after loading her up with the 300# of sand, and doing the 2 minute rinse, she is as clear as can be and filtering now. 'Clean' pressure is 12psi so when I hit 22psi time to backwash. Now I am wondering why I didn't get one last year. Thanks to everyone here at TFP for helping. I will post pictures this weekend.
    Yes I couldn't wait to hook this bad-boy up! glad i did.
    Regards and happy pool season to all
    Dave
    Dave Graham
    38,396
    Hold on there big fella ....
    We recommend backwashing when the pressure rises 20-25% over the clean pressure. Waiting for 10 psi rise is WAY too long.
    So, you should be cleaning around 15 psi.
    Mar 2014
    Chesapeake, VA
    74
    ah, will do that. I know the papers with the filter said 8-10psi rise. but you say 15 psi, and my clean is 12psi. will follow guidance from the group
    Dave Graham
