Results 1 to 12 of 12
Thread: CYA Level...
    Jun 2013
    Newcastle, Oklahoma
    508
    CYA Level...
    Went ahead and opened pool, water temp is hovering 58-60 degrees, as i said in earlier post, its crystal clear.
    uncovered, got pump going, topped pool off and ran pump for about 4 hours, enough to flip pool ~1.5 times.
    Sat overnight, just got through testing:
    CYA - 35ppm
    FC - 8 ppm
    CC - 0
    pH - 7.7
    TA - 90
    CH - 170
    according to pool calculator set to TFP recommended goals, I should be between 30 and 50 on CYA
    Last year I was wayyy high at 80 and I just let it be and used more chlorine.
    now this year im on the lower end of the spectrum at 35.
    its it better to be closer to 30 or 50?
    or should I just leave it alone?
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: CYA Level...
    secondary question, we wont be using this pool for probably 6 weeks.. (mid May) due to temps.
    with no bather load and cool temps, will running pump 2 hours a day be sufficient until we start using it?
    Jan 2013
    Houston, TX
    1,079
    Re: CYA Level...
    The CYA level look s good to me. Some would say that you may want it a wee bit higher if you pool gets a lot of direct sun.
    Looks like 2 H per day (based on your signature) gets you almost a full turnover ... should be fine.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    38,235
    Re: CYA Level...
    You should only wait for the water to warm up for the CYA test ... the pH and chlorine will change from sitting like that, so they may not be correct.
    I would leave the CYA where it is and see how it goes, if you are having to add more than 2-3ppm of chlorine every day, then raise the CYA a bit to better protect it from the sun.
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: CYA Level...
    thanks. what temp is ideal for cya test?
    and this pool is in direct sun all day long
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    CYA Level...
    How much sun does your pool receive ? I like to have CYA at 40 ppm. It's kinda middle of the road if you need more protection from the sun you can always go to 50 ppm
    I think you should be able to get away with 2 hrs of run time until you start using the pool. Will it be covered during this time ? 😎
    Jeff
    38,235
    Re: CYA Level...
    Room temp say 70+ When the water is cold the reaction takes longer. You could test with the cold water, but would have to wait more than a minute to hope the reaction was complete or you might get a lower reading than reality.
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: CYA Level...
    Quote Originally Posted by pwrstrk View Post
    I think you should be able to get away with 2 hrs of run time until you start using the pool. Will it be covered during this time ? ��
    sun all day. no it wont be covered during that time
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    CYA Level...
    If you get sun all day you might want to be at 40 ppm CYA. Wait and see how much FC you lose.
    You'll still be good for your pump run time. 😎
    Jeff
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: CYA Level...
    i let it sit for a minute after I added the solution to the dot tube. but in light of the low temps, ill test again in 3-4 weeks. this was my last CYA test too so time to order some new reagents.... need some more DPD powder too...
    thanks fellas!
    38,235
    Re: CYA Level...
    Well, you just missed the tftestkits.net refill sale which ended on Monday
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: CYA Level...
