Results 1 to 11 of 11
Thread: Lost Water / Leak? / Floating Liner... HELP!!
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I am down at least a foot ..... but i do have water underneath the ice.
    Any chance it could be from evaporation?? I googled it and found one person who said he loses that much every winter and there is no leak once he fills it back up .... i know that is a longshot and i most likely have a leak.
    Should i refill it and see if it drops down? Assuming it drops to the same level then that is where i start looking?
    Would expansion of the ice potentially cause an issue?? I know it is tough to troubleshoot this stuff site unseen but i want to get started. We have rain and above freezing weather and i want to get started now.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Nov 2011
    Albany, NY
    495
    Re: Lost a ton of water this winter.
    ANybody??
    Haywood Sand Filter
    Vinyl Liner
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I vote for fill it back up and see what's going on. 😎
    Jeff
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by pwrstrk View Post
    I vote for fill it back up and see what's going on. ��
    thanks ...... i guess it's kind of a no brainer to do that to start
    my neighbor's pool is way low too
    all i need is a little more of the ice to melt and i can get a hose under the ice and start filling
    Haywood Sand Filter
    Vinyl Liner
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Is it too thick to break a spot up ? 😎
    Jeff
    Nov 2011
    Albany, NY
    495
    Is it too thick to break a spot up ? ��
    No .... but it seems like some of the edges are frozen solid to the liner ..... so i am worried about ripping the liner if i go under the block of ice with the hose and raise it.
    I have about a foot of water in the shallow end so from what i have read that is enough ..... it also seems to have stopped dropping so i am hoping it isn't a main drain issue. I read online about issues with the ice having sharp edges and during a warm spell melting enough to move and the sharp edges tearing the liner. It actually mentioned a very widespread issue in the year 2000 where there was a swath of land from michigan to maine that had unusual weather and an abnormally large group of pools were damaged.
    Haywood Sand Filter
    Vinyl Liner
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I know what your talking about. Wait till it melts and comes away from the liner. 😎
    Jeff
    Vette's Avatar
    Jul 2012
    Ohio
    404
    I'd sit still until all is melted. No reason to rush or panic. Carry on as normal and then you can do a bucket test (for leaks) once opened.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Vette View Post
    Thanks .... i think i will go that route ..... it seems like i am not losing any more water.
    On the down side i pulled the cover back and my liner is floating up ..... so i will have some issues to address for sure.
    Haywood Sand Filter
    Vinyl Liner
    Mar 2014
    Central AL
    59
    Ours lost about 9" over the winter from late October to early March. We just bought the house so this is the first year with it. It hasnt seemed to really lose any for the last 3 weeks since we opened it. At least no amount that I wouldnt consider evaporation.
    I had it covered during the winter, but we had a lot of wind over the winter that was able to get under the cover several times. There was also an inch or so of ice in it a few times.
    Russ
    33' diameter, 25,000 gal Above Ground Pool
    Pentair Dynamo 1.0 hp, 2 speed pump (#340204)
    Pentair Sand Dollar 60 filter
    Nov 2011
    Albany, NY
    495
    Nightmare over the winter ... what happened / what next?? Liner / Leak issues
    Well i posted a couple of weeks ago about my water level dropping. I must have lost a foot or more and it seems like it was all during a couple week stretch when it first warmed up a little. Now that i have taken the cover off i have found my liner is floating up quite a bit. For the most part it is just the sides with one small part of the bottom floating.
    Whatever leak there was appears to have stopped as the water level seems to be the same for a couple of weeks now. I read online about a situation with ice forming early and then a thaw with windy weather shifting the ice pack in the pool and causing sharp edges in the ice to tear the liner. That article mentioned that in the year 2000 or so that a stretch of the country from Wisconsin to Maine had an abnormally high rate of problems with torn liners.
    Of course i could be 100 percent wrong!
    Anyway i just pulled the cover off and i did notice a sharp piece of ice sticking through the cover. Here are some pics.
    I have been reading about pumping out the water from behind the liner? The liner is in good shape overall and i would love to be able to fix this issue without replacing it. Can i do it myself? Should i hire a guy? Soon?
    Any input is greatly appreciated!
    Haywood Sand Filter
    Vinyl Liner
