FC is 36.5
Took a little later than I expected to be able to test, it's been 3 hours this time. Dropped from 39 in a little over 3 hours.
I may test it again later tonight, but it's been dark for an hour or so. I'm guessing I won't need to add any chlorine tonight? I may just wait until tomorrow, since I'm guessing it shouldn't be worse than the decline over the past 3 hours?
I will add chlorine in the morning if I need to. We will probably be leaving in the morning and be gone for 5 hours or so, so I'll test right before and I don't know, maybe add to bring it up a little higher than I think I need just in case?
My CYA test came in anywhere between 65-80, and the 65 may be more accurate. I was aiming for an FC of about 28, so before I leave in the morning, maybe I should add as much chlorine (if needed) to bring it to about 32 or so in order to (hopefully) keep it from dropping too low?
It's supposed to be sunny tomorrow.
I don't have a light, but I'll try to pay special attention to the areas around the ladder, eyeballs, and drain? Right now there are still some pockets of leaves in the bottom, and I know that although I am trying, I'm probably not effectively brushing every spot. I can't see what I'm doing.
I'm going to use the leaf rake tomorrow afternoon, and I'm considering running some water to waste and filling - I don't know if a few inches will help to affect the CYA. And see if I can get the bottom vacuumed at all after that - there is sediment and gunk that needs to come out. And yes, weird mats, continuing to scoop. I'm guessing pollen then.
I'm getting (hopefully) quick enough at doing the test. In the beginning I had to keep referring to the directions and checking bottles, but since I'm repeating FC test over and over, I pretty much know what I'm doing with that one. I add the drops slowly but it's probably less than half a minute start to finish, and I'm doing a lot of drops right now.
I really appreciate everyone's help.
And the guy at the pool store tried to tell me more stupid stuff while I was there. I see what y'all mean.
