Thread: Type of sand in sand filter
    Jul 2011
    SW France
    105
    Hi everyone!
    it's that time of year again when the excitement builds as the weather begins to get warmer...and the pool needs to be put back into action. This year I feel I need to change the sand in the sand filter, as it's been in there 6 years possibly 7, can't quite remember. I changed the pump last year and the flow rate/pressure proved to be troublesome (read slow/high), so spent almost an hour flooding out the sand filter tank with a water hose trying to clear the sand...but although a lot of muck came out, I never managed to get clear water and eventually stopped for fear of needing a loan to pay for the water. Seeing that the sand has now had a chance to dry out over the winter, I'm guessing now would be a good time to replace it as hoovering will be simpler.
    Question;
    1) Local pool store suggests that I should have a "bigger" sand in the bottom followed by a finer sand - is this right?
    If I do need to mix sand, what are the ratios and qualities?
    if i should use just one sand, apart from the obvious that it needs to be pool sand, is there a particular grain size that I should be using?
    thanks for any help,
    R.
    SWG - Exterior
    12x5M
    90,000 Ltrs /24,000US gallons
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Re: Type of sand in sand filter
    You want #20 silica sand, sometimes called pool filter sand. If I remember correctly that is .45-.55 mm.
    Commercial pool filters use gravel in the bottom and sand on top of that, but it really doesn't make much difference in the smaller residential filters, so residential filters normally use all pool sand.
    Jul 2011
    SW France
    105
    Jason, thanks for the info and reassuring me. I must admit to having come up blank for mixing gravel/sand in a pool filter - every "how to" on changing sand only shows one type being used, so not sure why the pool shop would suggest that I do this, knowing that I only have a residential pool.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Jul 2011
    SW France
    105
    right...changed the sand...all 130kg of it....not a job for the faint hearted even with a vacuum. Filter pressure now runs much lower, so that's a great improvement. I won't be doing that again any time soon but worth doing.
    Pool is now shocked, clean, but a little chilly still.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Hadn't thought about how it would be much easier to change sand in the spring when it's dried out. MUCH easier than trying to get wet sand out!
    Isolated Spa - 345 Gallons
    jackrogue's Avatar
    Dec 2012
    Kailua-Kona, HI
    28
    Quote Originally Posted by JasonLion View Post
    You want #20 silica sand, sometimes called pool filter sand. If I remember correctly that is .45-.55 mm. Commercial pool filters use gravel in the bottom and sand on top of that, but it really doesn't make much difference in the smaller residential filters, so residential filters normally use all pool sand.
    Ahhh . . . . sand . . . the things we didn't know!
    What is Sand Made of? History.
    http://www.nature.com/scitable/blog/...s_sand_made_of
    "The primary component of typical beach sand is quartz, or silica (SiO2)."
    http://geomaps.wr.usgs.gov/parks/coast/sand/sand.html
    Parrotfish play a significant role in bioerosion while feeding on seaweed and polyps. Their sturdy beaked mouths and pharyngeal teeth grind up coral and coralline algae ingested during feeding. After digesting what is edible, they excrete the remainder as sand --- one fish can produce 200 pounds of white sand per year.
    https://en.wikipedia.org/wiki/Parrotfish
    Fish Funnies - Parrotfish: The Ultimate Sand Factory
    http://www.youtube.com/watch?v=gATMD5RTYmk
    14,400 GALLONS -- INGROUND 40'X12' GUNITE LAP POOL BUILT 1994 -- EP-4 ECOPUMP VARIABLE SPEED -- TRITON II TR60 SAND FILTER 63 GPM
    PoolMath
