Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: First Pool, First Time Test Results
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Hi guys, I just bought my first house last November, and am a first time pool owner. I've been lurking around here for a while, and have been putting off getting started as we've moved in, but I finally got my kit this week and have my first test results. Doesnt look good! I've had a pool guy taking care of the pool for the last few months and I wasn't really expecting it to be up to par but man! He's been using the pool pills and the guy I bought the house from also did. Im also in an area with very hard water down in south texas. So here are my results! Any tips or should I fill it with concrete? lol. This is my first test, I also haven't bought any chlorine, acid, etc. yet.
    FC = 15.5
    CC = 0.5
    pH = 7.8
    TA = 170
    CH = 550
    CYA < 100
    The pool is an inground, oval pool, 15 x 30, 5 ft deep. Pool calc estimates 15k gallons. I think its plaster? Older home built in late 70s.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It's not all that bad. We've seen worse. You can get a better idea on your CYA level by using half tap water, half pool water, then double your reading. I would lower that CYA level down to 40 ppm to 50 ppm level. So you'll need to replace some water. Pool math will tell you how much. Just don't do it all at once. Don't want to risk damage to your pool.
    Your FC would be good if your CYA level was 100 but we don't know your true CYA level so it's probably a bit low.
    Your going to have to keep an eye on the PH with higher CH level to prevent scaling. Also the PH test is skewed with an FC level of 10 or more. Use acid to keep that level into the lower 7's. If your having fairly quick increases in PH then you could lower the TA. The TA will also drop slowly on its own when you keep adjusting the PH. There's people here with higher CH levels than yours. What's the CH of your fill water ?
    You are planning to switch over to liquid chlorine (bleach) if you don't have an SWG right ? I hope so !
    If you could add all your pool and equipment info to your sig that will help us help you better. 😎
    Jeff
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Re: First Pool, First Time Test Results
    Thanks so much for the advice. How often should I test for CYA? I noticed the first test took 7 ml of my 22ml bottle of reagent. Is there a way to test without using so much?
    Also, yes I do plan on switching to liquid bleach and making the dreaded call to my pool guy. Should I be able to find the muriatic acid at like a home depot? I'll test the CH of my fill water when I get home. Also, as far as steps should I first get the CYA in line, then add acid to get pH down?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You may want to tackle the CYA first due to your high FC level and that throwing off your PH test. PH test is skewed with FC levels of 10 or higher.
    Use the dilution method I described above to get a more accurate test of where your CYA level is and then use pool math to determine how much water needs to be replaced. While your doing that your FC levels should be drifting down and then retest PH and adjust if need be with acid to the lower 7's. 😎
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Marcellus! Just curious, how far South are ya?
    Once you get a good Cya number, you don't want to re-test until there has been a major water replacement.
    You say the Cya is <100, but re-test with dilution as Jeff suggested and report back on number if you would please.
    Your CH is a little high, but it can be manageable at that level, and maybe your fill water can lower it by replacement. If you really want to know that, simply run a CH on the fill water and see what it says.
    Essential Links:
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Thanks so much for the advice guys. Brush I'm down here in good ol San Antonio! I retested the CYA today using half tap water and it is apparently still a bit over 200. Also the CH of my tap water I believe is about 240, but its kind of tough to tell the difference between purple and blue. According to pool math with an estimate of 220 CYA its saying replace 82 % =/. But the water is soo clear, lol.
    Also, here's a pic of the beast herself. Don't mind the plants, they're a project for another day.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Are you going to do the water replacement ? If it were me I would. That's a high CYA level. I wouldn't even know what FC level to maintain for that. 😎
    Jeff
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    I think so, I want to get started off right. I was reading that I should replace it in thirds. Do you think that would be best way to do it? My neighbor was saying he already has a sub pump.
    15' x 30' Oval In-Ground 13,500 Gallons, Built 1979, Millenium 27" Sand Filter, Centurion 2HP 56-Frame Pump, Dolphin Deluxe 4 Pool Cleaner
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes in thirds would be a good idea if your water table is high. You don't want to risk damage to the pool by floating it.
    This will be a good decision on your part to replace the water and lower that CYA level 👍 It's a win win situation. You'll be able to manage your pool a lot easier. With that high of a CYA level the only outlook to me would have been green. 😎
    Jeff
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    There should be some kind of network set up where people with a too-high CYA level can send their nice clean water to someone filling up a new pool and starting with zero CYA, in exchange for fill water sent back from the person with the new pool.
    New pool owner doesn't need to pay for CYA, existing pool owner doesn't need to pay for fill water, everybody wins
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    lol yea, you can definitely come pick some up if you need it!
    I'm almost done draining this thing guys! My neighbor had a sub pump and drains his pool sometimes, and said it should be ok to drain that much at once.
    Are there any other chemicals I need on hand to bring her up to snuff? I'll have some bleach, muriatic acid, and baking soda. I plan on hopefully having her back full by tomorrow, and testing the water tomorrow night to get her back started.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good. Post up some test results and we can go from there. The big thing is that CYA level. 😎
    Jeff
    30,414
    Pool School is your friend. You should be reading "ABC's of Pool Water Chemistry" to find out what, if anything, you will need for your pool and you must get some valid test results. Read the "SLAM" article as well because you may be required to do that to get things in line.
    A word of caution.......your neighbors' advice and ours may not be the same. Make a choice.....do not try to blend the two as you will end up caught in the middle.
    What we teach work 99+% of the time.....promise. If you are absolutely faithful to the advice, you can change that to 100%.
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Thanks, I'll definitely give it another refresh. I've been there and lurking the forums since I bought the house, I just wanted to make sure I have all my ducks in a row now that its the real thing. My neighbors pool was also green yesterday, so I'm definitely going to stick with the TFPC Method, he just knows the soil in the area better than I do. I was able to finish draining and refilling the pool yesterday/this morning, so I'll be testing again this afternoon starting fresh! Definitely have been looking forward to getting started, Thanks again for all the help!
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Just finished my first test since finishing the refill, test results are:
    FC 2
    CC 0
    pH 7.2
    TA 240
    CH 230
    CYA about 25?
    So should I add bleach to target a FC of 4, let the pump run to bring down TA and keep the pH where it is for now? I just started the pump about 30 mins ago since filling it back up
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Can you put those results like this
    FC
    CC
    PH
    TA
    CH
    And then add the numbers. It's a little hard to read the way you have it. Ok you fixed it.
    Jeff
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Sorry about that, I was starting a spreadsheet and tried to copy/paste. Saw how bad it was after, lol
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes raise your Fc with bleach to at least 4 ppm. You can go to 6 ppm. That will give you some wiggle room so you don't fall below your min FC level.
    If you need to lower your TA take a look at this. http://www.troublefreepool.com/conte...tal-alkalinity. If your PH is increasing quickly lower the TA until your PH stabilize's using the link I gave you. 😎
    Jeff
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Quote Originally Posted by pwrstrk View Post
    If you need to lower your TA take a look at this. http://www.troublefreepool.com/conte...tal-alkalinity. If your PH is increasing quickly lower the TA until your PH stabilize's using the link I gave you. ��
    Thanks so much, I think I will go ahead and raise the FC to 6, and also aerate to get started on lowering the TA.
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The TA doesn't have to be In a certain range. It all depends on where your PH is pretty stable. Then your TA will be in a good spot.
    Are you pretty confident on the CYA level ? The test can be tricky. Use the number the reading was closest to.
    Jeff
