Thread: Water leak on Sand Filter Pump, Model SF20110
    Water is leaking from the junction of the pre-filter housing and the motor water inlet. I replaced the two motor inlet o-rings, but this didn't stop the leak. I don't remember seeing a washer for the filter housing nut when I removed it (to get to the o-rings), but is there a gasket/washer that fits inside this nut?
    Any other ideas on how to stop this leak - short of replacing the pump?
    Thanks for your help
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Re: Water leak on Sand Filter Pump, Model SF20110
    Could you post pictures? May help us assist.
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
