Thread: New Mastertemp heater whines
    Aug 2009
    Novato, CA
    22
    Hello,
    I've recently installed a new Pentair Mastertemp 200 heater. The blower motor has an intermittent high-pitched whine. I know it's not the "flame too rich" problem the troubleshooting guide mentions because it occurs even when the burner cycles off and/or when I turn the gas supply valve completely off.
    I saw one post in the archives about this problem but nothing about the fix. Does anyone have any further information?
    It's still under warranty, but I wanted to get as much info as possible prior to calling Pentair.
    Thanks.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: New Mastertemp heater whines
    Supposedly, Pentair has a different air orifice grate that will help with this issue. Give them a call.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2011
    Long Beach, CA
    2,790
    The whine could be caused by a couple different things, my in-laws had a whine that started on the second day that ended up being a broken piece of plastic. Call Pentair and setup a service call.
