Results 1 to 9 of 9
Thread: Installing CircuPool Si
    Oct 2012
    South Central PA
    6
    Split from this topic. Please ask questions in your own topic, rather than reusing someone else's topic. Thanks JasonLion
    Quote Originally Posted by timerguy View Post
    Oh ohhhhhh salinity is 4600ppm average- 4700 instant- the high salt is flashing still generating tho.
    timerguy,
    I just bought a Si45 and I'm trying to plan my install. I'm not a plumber, and I'm having trouble figuring out the dimensions of the connections for the cell and the flow switch. It looks like 1.5" PVC going into the cell and 2" going into the flow valve. Is that correct? Thanks for posting this pic, it's the best one I could find of an installed CircuPool SWCG.
    Re: I FINALLY got my SWG installed and running
    kshifle, the CircuPool Si uses 2" connections on all components. timerguy has 2" to 1.5" reducers, one just below the flow switch and the other on the right just after the cell.
    Fyi. The circupool comes with two reducer bushings
    Brian, Pool newbie in Atlanta, GA. 24k IG vinyl pool, Circupool SI-45 SWG (purchased 3/2014) , Hayward Pro Series Sand filter S220T, Pentair 1hp 2-speed superflow (thanks Jbizzle!), TF-100 test kit w/ SpeedStir
    Removed -> Hayward 1HP Super pump SP-1607-Z1-M
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by kshifler View Post
    timerguy,
    2" in all though there are (2) 1.5" Adapters for the cell. I used one for the cell and one for the flow switch. more adapters could be purchased at any Lowes or Home Depot 2" elbows and any union connectors as well.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Oct 2012
    South Central PA
    6
    Thanks for the replies, I think I have it figured out. My Si45 came with 2 of each of these: 1.5" connectors, 2" connectors, and 2"->1.5" reducer bushings. The reducer bushings were already inside the 2" connectors, once I popped them out it made more sense.
    Here are my planned connections, water flows left to right:
    1.5" PVC -> reducer bushing -> 2" flow valve -> 2" PVC -> 2" cell connector -> cell -> 1.5" cell connector -> 1.5" PVC
    Any issues with using a 2" connector on one side of the cell and a 1.5" connector on the other side of the cell?
    38,254
    That should be fine. Make sure you have adequate straight pipe in front of the flow sensor.
    How much would you say is adequate? I'm building mine as we speak. (Just assembling so I have all the cuts)
    38,254
    Re: Installing CircuPool Si
    Whatever the manual says ... I think the Hayward says 12"
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by JasonLion View Post
    But I discovered today, they're not the ones that came with the Si-45. The ones shown in my picture actually came in the vertical installation kit they sent me. To plumb my new replacement system, I had to go to lowes to get a 2 to 1.5 fitting.
