I am thinking of replacing the motor on my SuperPump with a VS motor (Ecotech EZ or V-Green). I am leaning toward the V-Green (its more $$, but it has an aux output for a SWG). No need to a separate timer or current sensing relay.
I also want to replace my returns, they are 14 years old. I came across the iJet. It is a return that has a variable orifice based upon flow and sell for $21 each. It is a gimmick?
http://www.paramountpoolproducts.com/products/ijet/
I don't know if it is worth the additional expense. I will most likely be running the pump at a high speed just to power my Polaris 360. I will most likely run the pump to have enough flow to keep satisfy the flow switch on the SWG.
