Results 1 to 9 of 9
Thread: Pool Remodel
    texasliz's Avatar
    Mar 2014
    Austin, TX
    3
    Pool Remodel
    I'm getting ready to update my 30 year-old pool in Austin TX; getting bids - which led me to this great forum. In the past have done most of the repairs myself. Maybe I'm getting smarter as the years go by - this time I'm going to enjoy my morning cup of coffee and watch someone else do the job. Quite a transition for the hands-on person... Anyway, before I write the novel that puts y'all to sleep, your expert insight is most appreciated. I have a gunnite surface that I repainted w/pool-epoxy, now flaked off. Using SWG that I'm thinking of switching out to liquid chlorine. Motor: 1.5 horse/SS; thinking of using either a VS or 2 Sp. pump. Also have separate motor for Polaris cleaner - one bidder suggested changing to different model Polaris w/larger hose that runs off main pump so I could eliminate one motor. Plan to make this as maintenance-easy as possible, including water self-leveler, remote timers and auto-on freeze protection.
    Any recommendations on what is the best finish here, recommended equipment, contractors used, other insights?
    Thanks!
    Elizabeth
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Pool Remodel
    If the SWG is working I wouldn't switch to liquid chlorine....It does the job of you hauling bottles of bleach.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,319
    Re: Pool Remodel
    Welcome to TFP!!!
    Finishes depend on your budget and desires. Generally painting is NOT a good long term solution.
    Stick with any of the major manufacturers and the equipment is basically the same.
    What is you cost of electricity? If not too high and you have no special high flow needs, you are likely better off with a smaller 1HP 2-speed pump (if your current pump is in decent shape, you could just change the motor to a 2-speed.)
    I would also consider eliminating the boosted pressure cleaner and either get a suction, non-boosted pressure, or robot cleaner.
    texasliz's Avatar
    Mar 2014
    Austin, TX
    3
    Re: Pool Remodel
    Thanks - appreciate your input
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Remodel
    Welcome Liz. H&H Plaster in Austin has a very good reputation.
    Essential Links:
    texasliz's Avatar
    Mar 2014
    Austin, TX
    3
    Re: Pool Remodel
    Thanks! H & H came out today. Very knowledgeable sales rep.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool Remodel
    You've already been gives some good advice, so I will simply welcome you to the forum!
    Casey's Avatar
    SW PA
    10,448
    Re: Pool Remodel
    Welcome!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool Remodel
    Welcome to TFP ! 😎
    Jeff
