Results 1 to 7 of 7
Thread: Reviving old pool
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Reviving old pool
    Good morning, now that it is starting to turn to "spring" here in the northeast and temps are supposed to get above 50 I am starting to get itchy to start working outside.
    Here is what I want to do and I am looking for advice.
    I have an old gunite pool built in the early 70's. The pool is ok, does not leak, needs new waterline tiles and I am sure a good cleaning (this will be our first summer in house).
    Around the pool there is an existing concrete deck, maybe 3 feet wide, it seems to be in good shape, although painted/stained blue. At first I thought about ripping this up and installing 1200 feet of 4x8 pavers around pool. Now I am thinking of leaving the concrete because of work to remove it (what is the best way to remove it without damaging pool), disposing of conrete and it saves me money on brick.
    So the question is "Is butting the pavers to the concrete a good solution? How can I make it look good (if I can)? Would I need an expansion joint in between?
    Or should I just remove old concrete, which was my first plan and if so what is the least impacting way of getting this out?
    Thanks
    Having trouble posting pics via manage attachements
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Reviving old pool
    I can't comment on anything except how to post photos. Use a free hosting service like photobucket.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    TF100 test kit
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    If the concrete is in good condition I wouldnt remove it unless you just dont like it.
    You can butt the pavers up to it without an expansion joint because the sand below and between the pavers is porous. You could use a smaller paver or a brick on edge at tbe transition where the pavers butt up to the concrete
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    Jan 2013
    Houston, TX
    1,079
    Probably a better result and cheaper than removal & pavers to have it resurfaced / stamped / stained etc.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    I stained the basketball court in our backyard and plan to paint a logo (Kentucky Wildcats) on it this summer. The stain was more solid than I though but turned out nice.IMG_642064584571638.jpg
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    karmabiker, I also want to make the patio way bigger, currently as you can see in the pictures there is the 3 foot wide existing deck and then all grass and dirt, which I dont want. There really is no place for tables and chairs except in the grass and dirt.
    Willi, the concrete does seem to be in good shape besides color. so I might just keep it and butt brick to it like this pick that I saw on the web
    nice they are still in the tourney
    TF100 test kit
