Thread: Strange stains
    Jan 2014
    Perth, Australia
    31
    Strange stains
    Hello all,
    Recently I have noticed some strange stains on the pool surface, I have only noticed them on the shallow end. It looks like rust embedded into the pool area (), and even scrubbing it off persistently with a pool brush didn't help.
    Any idea what it might be? See in the attached photo, the smudged brown point just in the middle of the frame.
    Many thanks in advance!
    IG Fiberglass Pool - Sep/2013
    Pool capacity: 27,700 liter / 7,317 gallons
    Emaux V Series Sand Filters - Model: V700B; Size: 28"; Flow Rate: 89 gal/min
    Viron eVo P320 Pump; Flow rate (low/med/high): 32 gal/min, 56 gal/min, 66 gal/min
    Viron V18 pH Salt Chlorinator + RolaChem RP9 Automatic pH Controller
    38,371
    Re: Strange stains
    They could be rust / metal staining. Try rubbing a vitamin C tablet on them and see if they lighten or go away.
    Re: Strange stains
    Slepax, did you get a chance to try the Vitamin C tab? I have similar stains and this is the first I've heard of using Vit C. I need to go pick some up but was wondering if it worked for you.
    SunStone Blue Mist plaster; 20,000 gal; 39.5' x 16' (22' at in-pool bar seating), 118' perimeter, 626 sf surface area; 3'6" x 6'6" depth; trichlor auto-dispenser; 2 hp Jandy Stealth Filter Pump; 160 gpm Jandy water feature pump; 460 Sq. Ft. Jandy Cartridge Filter; Jandy RSPS 4 with PDA remote; In Line Chlorinator; A&A Infloor Cleaner; 2 Jandy watercolors LED lights; Ozone Sanitation
    Jan 2014
    Perth, Australia
    31
    Re: Strange stains
    No, I haven't. It's still on my to-do list. I will post something back on the forum once I have more info.
