Results 1 to 7 of 7
Thread: SWG settings in autumn / winter
    Jan 2014
    Perth, Australia
    31
    Hello all,
    So the weather is changing here downunder we're heading towards winter. The days are cooler, less sun, and the pool hardly get used.
    During summer, I used to run the SWG for 7 hours at 50% and that resulted with FC of 4.5 ppm.
    I have reduced SWG runtime to 6 hours (which means 1.9 ppm of FC generated daily) and my FC keeps rising by the day. I didn't complete the test but I've managed to reach 11 ppm and the solution colour was still strong (using the Taylor kit).
    Does it make sense that I will need to drop my SWG run time to say 4 or even 3 hours during winter? Or alternatively, keep it at 6 hours but lower production at say 25%? This will make only 1 ppm of FC daily, should I aim for less or more? I guess that depends on FC consumption but how can I predict that considering the pool has very limited use?
    Thanks!
    IG Fiberglass Pool - Sep/2013
    Pool capacity: 27,700 liter / 7,317 gallons
    Emaux V Series Sand Filters - Model: V700B; Size: 28"; Flow Rate: 89 gal/min
    Viron eVo P320 Pump; Flow rate (low/med/high): 32 gal/min, 56 gal/min, 66 gal/min
    Viron V18 pH Salt Chlorinator + RolaChem RP9 Automatic pH Controller
    Jun 2011
    Long Beach, CA
    2,780
    Re: SWG settings in autumn / winter
    You will need to reduce the SWG's output and it is up to you on how to do it. Both ways work fine, reducing % and/or reducing the pump run time. If you want to save some $ on your electric bill, reduce the pump run time. Each pool is different, but during the winter I run mine for 4 hours,mostly on low-speed, and have to reduce the % to 20-25% and the pool stays clean and chlorinated. You will need to experiment on what is best for your pool, just keep an eye on the FC and adjust accordingly.
    Generally you need more pump run time and more chlorine when the water is warmer, and not so much when the water is colder.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    During this past winter I went from 8 hours a day at 60% output to 3 hours at 10% output.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Here on the other side of the Earth, my chlorine demand has been rising fast this last week. The days are getting rapidly longer, the sun is coming higher over the trees and the trees are dropping lots of stuff in the pool. I'm still below peak summer levels, but getting close fast.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Jan 2014
    Perth, Australia
    31
    Quote Originally Posted by JasonLion View Post
    Thanks all. So just to clarify, the amount of chlorine I should be targeting is driven by water temperature and not air/outside temperature? Because some days are still warm, but the water is colder than before (I would say now it's ~26C/79F).
    Right, water temperature is the largest factor, followed by number of people swimming (which is probably nobody right now).
    Just to be through, the FC level you are trying to maintain is the same as always. It is the amount of chlorine required to maintain that level that goes down.
