Results 1 to 14 of 14
Thread: Resin Above-Ground Pool Fence Kit On a 20' x 54" Intex Ultra
    Jun 2013
    west fargo
    72
    Hello, I just ordered a 20'x54" intex ultra and I am being told that I should get a safety fence.
    My Yard is not fenced in currently so it would be a wise choice. I am just wondering if anyone has installed one.
    Also how was it to install? Also how many sections do you think I need? It seems like 22 but not really sure.
    http://www.amazon.com/gp/product/B00...=AGOKDG42D8KUC
    This is what I am looking at currently.
    Thanks for any advice
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Resin Above-Ground Pool Fence Kit On a 20' x 54" Intex Ultra
    I am not an expert on above-ground pools, but I don't think that fence will work with an intex pool. Hopefully someone more certain will comment!
    Orlando, FL
    690
    Melt, I didn't thinks so either but I just found this and it has been done
    http://www.troublefreepool.com/threa...e-with-Fencing
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2013
    west fargo
    72
    Ya that is what I seen to I also seen some when you google it. I am just wondering how hard it is to do it seems simple but no one gives details
    Jun 2013
    west fargo
    72
    So know one has seen this done anyone have any other thoughts on fencing without fencing the whole yard?
    Jun 2013
    west fargo
    72
    After planning to use the fence on a Intex pool I am certain that it will be pretty simple to put together.
    20'x54" intex ultra Sand filter. with SWG Still work in progress will have Resin 24" fence around the top. Hooked to a 10x6 Deck that is attached to another 10'x6' Kids Club house. Slide from main deck into pool. Intex softwall lights. Kenwood Marine radio sealed in a deck box all Bluetooth controlled with Pyle 5" outdoor speakers.
    Casey's Avatar
    SW PA
    10,448
    Please post pics during and after install.
    Jun 2013
    west fargo
    72
    I sure will I am working on the ground prep for the pool but I will for sure post some steps etc.
    Jun 2013
    west fargo
    72
    Here is the mounting of the brackets.
    [IMG][/IMG]
    Casey's Avatar
    SW PA
    10,448
    Cool! Post pics when done!
    Jun 2014
    Springfield, Illinois
    1
    Cannot see the pic attached..help
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    aircare88: Welcome to TFP!
    If you are talking about the pic in post #9, I see it fine. Maybe the original poster edited the post to get the pic to appear.
    Jun 2013
    west fargo
    72
    I am going to be doing the full install of this fence tomorrow. I will post pictures as I go.
    update it is tomorrow and it is raining once again. So the Fence will have to wait another day or 2
    Jul 2015
    Delta
    9
    Did you ever post pics??
