Thread: Water Seepage Below Tiles
    Mar 2014
    AZ
    2
    Hi everyone,
    I recently found this site (already ordered and received the TF-100 testing kit), and I could use some help and advise.
    We've just had our pool redone with StoneScapes Mini Pebble. PB had to come back, drain the pool and do another acid wash as there was quite a bit of mottling on the bottom and sides. I noticed water spots under the (new) tiles. Is this something to be concerned about. They are coming to fill it tomorrow, for the second time, and I'd hate to have this be a major problem and not get it taken care of before filling.
    Thanks
    12K, Aqua Blue StoneScapes Mini-Pebble, 1HP Hayward Pump & Cartridge Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Water Seepage Below Tiles
    I doubt it is a really serious issue. But, is there any grout in that joint?
    Jan 2013
    The Great State of Texas
    243
    I have to agree, it looks like there is no grout. Surely that is an optical illusion?
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
    38,548
    The grout is there ... it is just wet and darker.
    Somehow there is water behind the tile (whether it got there from the pool or ground water) that is now seeping out. Ideally this would not happen, but I imagine it is fairly common.
    Mar 2014
    AZ
    2
    Thank you for the replies. Yes, there is grout between the tiles. It's a dark blue color so it doesn't show up that well in the photos. It appears to be drying out. PB still needs to repair a couple of spots around the drains before filling.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Melt In The Sun View Post
    I agree. From the shots above it looks less filled than the other joints.
    Essential Links:
