Results 1 to 18 of 18
Thread: Best way to measure volume of vessel without knowing dimensions
    Feb 2013
    Pool Country
    138
    What is the best way to measure the volume of a vessel without knowing the dimensions of the vessel?
    I was thinking of adding calcium chloride and measuring the increase. I would use an extra large test sample to get more precise results. Then I could correlate the test results to the dosage requirements on the container of the calcium chloride.
    Any better way to do this?
    Thanks
    38,248
    Re: Best way to measure volume of vessel without knowing dimensions
    There is precision error in any test. I would not add any chemicals for the sake of coming up with a volume unless you actually need the chemicals.
    You can get a general trend over the course maintenance by using PoolMath and testing after any chemical addition to dial in the pool volume.
    delirium330's Avatar
    Dec 2013
    Sacramento, CA
    104
    What do you mean "without knowing the dimensions of the vessel"? Why don't you just measure it? Here are some suggestions if the shape/depth is complex and not a standard rectangle or square:
    1. Find the pool builder and ask them.
    2. Check local permits/records, if they don't have volume they will often have sq. footage.
    3. Break up sections of the pool into reasonable rectangular sections and measure volume for each section then add them together. If you want to get crazy like I did, use some graph paper and draw the pool to scale, then do your section measurements. Do the best you can to get close, but feel okay if you're inaccurate. After you do that you'll be able to move the estimate up/down through chemical maintenance and Pool Math as jblizzle suggested. I got within 1,000 gallons upon my graph paper method which was only 7% off after I refined it. Even 7% is somewhat immaterial to the Pool Math calculations.
    Built 2003, 14k Gallons, IG Pebbletec, Primary Pump: Sta-Rite Intellipro VS, Sta-Rite Series 3 S8M150 Cartridge Filter, Fiberstars Jazz Light w/Color Wheel, Polaris 280 Vacuum (Runs Zodiac PB4-60 Booster Pump) and 2 Waterfalls (Run on separate, dedicated 1HP Sta-Rite Max-E-Glas II Pump).
    Feb 2013
    Pool Country
    138
    Quote Originally Posted by delirium330 View Post
    Do you mean the square footage 2 dimensionally or 3 dimensionally?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Measuring with chems can be tough especially with chlorine because it is not always the labeled strength. Dry chemicals is a little easier but you need accurate measurements which is not always possible with test kits.
    The following method gives both surface area and volume which can be useful when you need to replace some water because you can calculate the drain depth.
    Using either the house water meter or hose meter take a before reading then add enough water to the pool to raise the pool level 1" then take an after reading to get gallons per inch. Some house meters are in cu-ft already so you may need to take that into account.
    Surface area (sq-ft) = gallons per inch / 7.48 * 12 = cubic feet per inch * 12
    To get volume you can estimate the average depth by just taking the average of the shallow end and deep end. Depending on the type of pool and layout, you may need to adjust the depth due to stairs, benches and sloped walls. My adjustment was about 25% off the average depth (6 ft -> 4.5 ft) but I have fairly large stairs and a couple of benches.
    Volume (gallons) = Surface Area (sq-ft) * Average Depth (sq-ft) * 7.48
    The surface area is fairly accurate but the average depth less so but you can then confirm/modify using the chem method when available/accurate. Over time, you should be able to narrow it down further every time you add chems.
    Mark
    Feb 2013
    Pool Country
    138
    What I mean is, do pool builders and plasterers measure the square footage by the horizontal plane over the vessel or the actual surface area of all the surfaces that touch the water?
    Most of the ones I have run into measure the linear feet at the top of the pool wall and then use simple approximations of everything else.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by 09659 View Post
    I think it would depend on which you were interested in.
    If I were a plasterer, I'd be interested in the total square footage that contacts the water because that would determine how much plaster I have to purchase and how long it would take to lay that plaster down.
    If I were a pool cover salesman, I would be interested in the square footage defined by the horizontal plane over the vessel.
    Neither of those are measures of volume, which is likely what the homeowner is most interested in for filling and chemical additions.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by JasonLion View Post
    This, and or square ft of surface is what Pool Builders seem to use. Mine did, and others al talked to about other things say for plaster only asked me for this information.
    Essential Links:
    Dec 2013
    Sacramento, CA
    104
    Thanks
    Square footage of the surface area. This is a good site that I used to measure my irregular pool (see bottom-most portion). Again, was okay to get close then refine through Pool Math when adding chemicals.
    http://www.poolandspachemicals.co.uk/volcalc.htm
    Jul 2011
    Arizona & California
    803
    This link may be helpful: http://www.troublefreepool.com/threa...ng-Pool-Volume
    If the water needs more hardness and you can increase it safely, the formula number for adding 77% calcium chloride flake is 82,000.
    Feb 2013
    Pool Country
    138
    Thanks for the explanation.
    Feb 2013
    Pool Country
    138
    Internal Area =
    Average Width multiplied by Average Length
    plus
    Perimeter multiplied by Average Depth
    "Perimeter"? That doesn't sound right.
    Dec 2013
    Temecula - Southern California
    26
    Internal Area =
    plus
    This formula is actually surface area of the pool.
    20k gal, IG gunnite plaster + spa, 2 HP Whisperflo pump, Pentair 520 sq ft catridge filter
    Pentair Min Max NT heater. Intelli-touch i5 controller, Ultrapure ozone (currently disabled), Rainbow 320 chlorinator
    Small water feature, Water slide. Poolvergnuegen 2WD suction cleaner.
    Quote Originally Posted by whatsthispoolthing View Post
    That doesn't sound right either. Depth has no bearing on surface area.
    Feb 2013
    Pool Country
    138
    Semantics: the meanings of words and phrases in a particular context.
    Surface Area =
    Internal Area =
    plus
    Volume =
    Average Width multiplied by Average Length multiplied by Average Depth
    I see, internal area is a rough approximation of the surface area that needs to be plastered. More specifically, the area that needs to be plastered if the pool is a rectangular prism (which pools aren't).
