Results 1 to 10 of 10
Thread: Cal-hypo cloud
    Mar 2013
    CA
    28
    Cal-hypo cloud
    deleted
    38,251
    Re: Cal-hypo cloud
    We do not "shock" our pools. We follow the SLAM Process and we do it using bleach. Here in AZ with hard water and high evaporation it is not a good idea to add calcium to the water either.
    What kind of filter do you have?
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
    Aug 2010
    Dallas, TX
    4,052
    Re: Cal-hypo cloud
    Clouds from CalHypo are common. Also, if there was algae in the pool, the dead algae turns white.
    Mar 2013
    CA
    28
    Re: Cal-hypo cloud
    deleted
    22k IG pebble-tec pool, Pentair Whisperflo 2-hp pump, Pentair Triton II TR-60 sand filter
    38,251
    Re: Cal-hypo cloud
    We recommend backwashing when the pressure rises 20-25% over the clean pressure. If your clean pressure is 13psi, you should backwash at 16psi ... so you are well past due.
    You need to properly follow the SLAM process to confirm there is nothing in the water.
    Mar 2013
    CA
    28
    Re: Cal-hypo cloud
    deleted
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cal-hypo cloud
    Could be a lot of dead Algae, maybe some Calcium. I would SLAM and continue on, see how things progress.
    Essential Links:
    Mar 2013
    CA
    28
    Re: Cal-hypo cloud
    deleted
    38,251
    Re: Cal-hypo cloud
    Upgrade to a multi-valve
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cal-hypo cloud
    Yep, it is around here too. Always....
    Essential Links:
