Results 1 to 7 of 7
Thread: Arguing with the builder: GVA valve direction
    Jan 2014
    Buckeye AZ
    807
    Hi! Hayward PS-4 with a few Hayward GVA 24 actuators. After their design didn't work the way we wanted, I had to get in Visio and start diagraming for myself. I've got it pretty much figured out, but the builder is saying that the GVA valves go from left to right, and you can't have two valves going in opposite directions at the same time.
    that's hogwash right? You'd just move your 2nd valve into position and put the switch to ON2 so when powered it heads back the other way right? The hayward manual is fairly unclear about the ON1 ON2 settings.
    Re: Arguing with the builder: GVA valve direction
    There is a switch on the actuators that reverses the movement. They always move both ways, but one way is though of as on and the other way as off. The switch reverses which direction is thought of as on and which direction is though of as off.
    Jan 2014
    Buckeye AZ
    807
    Cool, right. Which direction to they rotate out of the box in On1, clockwise?
    38,524
    Generally you just hook them up and see if they are doing what you want. If not, flip the switch.
    Jan 2014
    Buckeye AZ
    807
    ya i know, but I am sending the contractor my diagrams, stating which ones need to be set to ON2, and how they should be cammed when in the "not activated" position, so knowing which way the currenly installed valves rotate helps. When I get home I can just go look at it, but...I'm not at home right now
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    38,524
    I do not think it is obvious just looking at them. I have no idea which is the "normal" On and Off direction.
    Jan 2014
    Buckeye AZ
    807
    I meant, turn on the valve and see which way it spins.
