Thread: Jandy valve question - what's the difference between 4717 & 4944?
    Apr 2013
    Orlando, FL
    7
    Question Jandy valve question - what's the difference between 4717 & 4944?
    As the title says, what's the difference between Jandy part number 4717 & 4944? Both are Pro series "Never Lube", 3-way, 2" - 2 1/2" valves that seem nearly identical.
    The only difference I've read from the data sheets is that 4944 has both internal & external stops - what does that mean? Does it change the operation of the valve in any way?
    19688 gal outdoor IG rectangular marcite, Pentair SuperFlo 1 HP pump, Hayward C1200 Star-Clear Plus 120 sqft cartridge filter, HASA Liquidator, Zodiac Baracuda T5-Duo suction cleaner.
    Fill water: FC 2, pH 7.8, TA 180, CH 150
    Apr 2013
    Orlando, FL
    7
    Re: Jandy valve question - what's the difference between 4717 & 4944?
    I've gone ahead and ordered the 4944; I'll update this thread once I receive it...
    38,403
    The Jandy valves typically did not have the external adjustable stops I did not think (Pentair did), must be a new variant that is shown here:
    http://www.zodiacpoolsystems.com/Pro...be-Valves.aspx
    There are other pics you can click that do not have the external stops.
    Apr 2013
    Orlando, FL
    7
    I've poured over their site, tech spec and system brochure links, etc. and still can't make heads / tails out of which model has which features...
    Edit: Sent e-mail to Jandy asking them to clarify.
    Apr 2013
    Orlando, FL
    7
    Apparently, they operate identically, but the 4944 offers extra stops to prevent someone from bypassing the external ones. "In some areas, code requires both external and internal stop to insure the valve cannot cause deadheading"
