Results 1 to 11 of 11
Thread: Stains, Gouges, Excess plaster issues
    I've been battling with a few issues that have made getting and keeping the pool clean and free of sediment difficult for a while now, and now that I'm getting there, I'm noticing staining in the plaster.
    The issue I'm having is that these "stains" seem to be little bulbs, maybe a bit smaller than a pea (though not round, they're rough) that exist on the plaster surface that are catching dirt such that even scrubbing them will not remove the dirt/staining in the cracks and crevices. I also have a few spots where the issue seems to be a gouge in the plaster, where sediment accumulates, then refuses to come out.
    Is there any recommended method to even out gouges or bumps in plaster?
    Appx 15,000 gallon (odd shape) IG Plaster, Hayward DE4820 DE filter, Hayward TriStar 1.58Bhp/1.0FRHp
    Pool built by previous owner, home purchased 11/2013
    Houston, TX - 2 dogs - Palm Trees
    Gouges and bumps in plaster
    This was posted in "Getting Started", then moved to "Under Construction", but didn't get any responses there
    Is there any recommended method to even out gouges or bumps in plaster (and also remove this yellowish/rust colored staining?
    Aug 2010
    Dallas, TX
    4,052
    Re: Gouges and bumps in plaster
    Do you have any idea how old the pool is? Can you post some pictures? Sounds like a similar issue I had in some areas of my pool.
    I'll try to post some pics when I get home this afternoon, unfortunately the pics will really just show the staining, since these bumps and gouges are on the pool floor. I found them when I actually got into the pool to attempt to scrub the staining... it does seem like more have popped up over the last few weeks, but I can't be sure - like I said I've been battling sediment, and I noticed a few several weeks ago, and it seems like more are popping up now, despite the sediment situation being improved drastically since I first saw them.
    I'll be getting new measurements this evening, but I did have high calcium hardness (over 400) and PH (over 8) at one point, and the pool was very likely that way for a few weeks or more when we got the home. It's now down around 250 and 7.3 respectively. My chlorine has also been fluctuating due to some issues with my inline feeder - it was around 0 at one point, up to around 2, back to 0, and now up around 4.5, which is my target.
    Unfortunately I don't know how old the pool is, judging by the decking, faded brick surround, etc, I'd say it's probably 15-20 years old, but that's just a guess, I could be off in either direction.
    I also see some "drainage" streaks in the plaster, under the filter return outputs and one of the skimmer cutouts... I'll try to get a picture of them, they're kind of light and the water is still a bit cloudy, so not sure they will be visible. It kind of looks like the light erosion you would get if water were draining out of those holes and down the pool wall... which doesn't make sense unless the pool was empty for a while and for some reason had water draining out of those spots. Other than that, I don't see any damage or wear on the plaster.
    Aug 2010
    Dallas, TX
    4,052
    Look at these and see if anything looks familiar. Note the ones underwater may be hard to tell what's going on.
    That second one maybe a bit, but not exactly - may be worth mentioning there's really just one, maybe two gouges - and they're pretty isolated. The main one is kind of a horseshoe shape, and maybe the size of the bottom of a small cup. As for the bumps, they're also just kind of here and there, not necessarily in clusters or focused in specific areas.
    Also, I edited my previous post to ad some data, looks like after you responded. Thank you btw.
    Aug 2010
    Dallas, TX
    4,052
    Re: Stains, Gouges, Excess plaster issues
    I thought the second one might be similar to what you were describing. That bump was caused by the plaster pulling away from the concrete. Don't panic though, let's see your pictures.
    Topics merged. Please keep everything related to one question together in one place, and never ask the same question in more than one topic.
    Sorry
    As for the gouges - Panic stifled. I'm hoping that's not what it is, like I said, kind of horseshoe shaped, like you took a small cup and kind of unevenly pressed it into the plaster while it was wet. difference between what I see and what's in the second pic, in your pic the dirt is outside the gouge - in my pool the dirt is inside the gouge, outside is clean and white.
    Anyways, thanks for the help, I'll post some pics later today.
    Aug 2010
    Dallas, TX
    4,052
    Sounds like the issue is reversed. The second picture is a raised area in the pool. You mentioned some bulbs, that's why I posted this. The other pictures are areas where plaster has "left the building".
    http://imgur.com/a/dKrjS
    Not sure how well these came out, the gouge is right near the middle of the pool, so I couldn't really get a close up.
