Thread: Inspecting Auto Cleaner / Proper way to not lose prime?
    Mar 2014
    Orlando, FL
    35
    Hi All,
    Is there a "proper" way to inspect the bottom of an automatic pool cleaner that doesn't suck air in? Should I not be running the pump when I do this?
    Currently, I pull it out of the water for 15-30 seconds, look at it and put it back in. Air does get sucked in, however I am not sure if this is a problem or not.
    I only have been doing it this because that is how I observed the pool service tech do it previously. Thoughts?
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Inspecting Auto Cleaner / Proper way to not lose prime?
    Either turn the pump off or do not fully pull the cleaner out of the water.
    Mark
