Results 1 to 9 of 9
Thread: Today is Pebble Fina Day!
    Finally, after 5 months of detailed backyard work, and waiting for the tile to cure . . . We're almost there!
    Cheers,
    Rey
    13.5K IGPool w/Spa, Gunite: Hayward Ecostar VSP3400, Hayward SwimClear3030, Sta-Rite Max-E-Therm Heater 333KBTU, Hayward On-Command pool automation system ; PebbleFina Sapphire Galaxy & Bella Blue, glass tile, Hayward ColorLogic LED Lights (3) Baha Shelf, "mini pool & waterfall" feature.
    Re: Today is Pebble Fina Day!
    Yea!
    Working Under cover
    It really wasn't suppose to rain until later tonight. We started the morning off with light drizzle, but it has become a heavy drizzle bordering light rain. So up with the tarps!
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Congrats. I can't wait for that day!
    I'd also like some rain (preferably on different days)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Bella Blue in view.
    -rey
    Nov 2013
    Ramona, CA
    46
    Awesome contemporary design for such a tight space....very NICE! Is that a waterfall in the corner and a spa off to the side?
    Yes . . .and it is a tight space. Today they started the "acid bath' phase. They suspend circulation pumps to help cure the Fina with the acid solution for a few days. The water is still a couple of inches below the true water line - and note we have a 9" waterline tile instead of the standard 6". The corner water feature is a little mini basin that will flow down the basalt wall when it gets to normal operation.
    We chose to do a two tone - with the spa and shelf dark to help heat the water a bit. We located near the ocean in So Cal - so every little bit of heat helps. The is the first 'two tone' pool our builder has ever done, or seen for that matter. I'm sure there out there. It does cost a bit extra to pull it off, since they have to take the time to rinse the hopper out and re-load with the new color.
    Still more work to be done - finishing the wood decks (plywood on them right now), and finishing the landscaping.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I think that two tone is nice! It may be a few years back now, but I know we've had another pool posted here like that. If I remember correctly, it had a white beach entry and shelf and blue beyond that.
    Two weeks later. Still lots of work to do to finish off . . .Wood decks, more landscaping and a few other details.
