Results 1 to 17 of 17
Thread: Is my backyard big enough for a 33' X 54' agp?
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    A tree fell on our 24' and we are considering upsizing. It may be a tight fit! Here's a pic! What do you think?
    http://instagram.com/p/l3gmZGQRmF/
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Is my backyard big enough for a 33' x 54 agp?
    A length of measured string should answer that question for you.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Thank you! We settled on a 30' by 54. In your opinion, is that a huge upgrade from a 24' 52? Thank you! If so, will the difference by subtle or noticeable?
    TF100 Test Kit
    Apr 2010
    East Texas
    9,600
    You just went from 13,500 gallons to almost 21,500 gallons. I'd say that's significant! 30 footer is a doggone good sized pool. I would recommend having two returns installed instead of the usual one if you can swing it.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Thank you. I actually just bought a new sand filter and pump that I was going to use on the replacement 24'. We decided to upgrade obviously, but the sand filter is a 24' Hayward inground sand filter and the pump is a 1.5hp 2-speed hayward power-flo matrix. Is that equipment recommended for my size pool? Or could I have went smaller or bigger.
    TF100 Test Kit
    Apr 2010
    East Texas
    9,600
    You should be in the ok range with those. I certainly wouldn't have gone smaller on the filter. Thumbs up on the 2 speed.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    In your opinion, should I run the pump on low for normal filtering and high for vacuuming? If not any ideas? Also, I noticed I'm okay in the filter, but I'm assuming a 26' would have been better?
    TF100 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by Metallica View Post
    You got it. That's how I run mine. On low for general filtering. I use high for vacuuming, mixing chem's and if I need better skimming action.
    Jeff
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    You guys are so helpful! So my 24 inch sand filter will suffice? Or should I have gone with a bigger?
    TF100 Test Kit
    Apr 2010
    East Texas
    9,600
    You'll be fine with that filter. Even bigger just means that much less backwashing before it gets dirty.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Bigger would not have been wrong. Smaller would have. Bigger filters less backwashing. You can use skimmer socks, nylon knee high over the skimmer basket. In the pollen season they help a lot. They catch a lot of stuff that would otherwise go to the filter. You just have to keep an eye on them as they can restrict flow when they get full. I use them all the time. I back washed my filter once last season. 😎
    Jeff
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Okay, I was just worried when you said I was in the "ok" zone. I was thinking "I knew I should have gotten the 26!!".
    TF100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You're ok with that filter. Dont worry, be happy
    Divin Dave,
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Sweet. Does anyone want pictures? As long as everything goes ok of course.
    TF100 Test Kit
    Post away, we would love to see pictures.
    The way I see it the bigger the pool and deck the less I have to mow.
    34,000 gal, IG vinyl lagoon shape, Pentair intelliflo varible speed 3hp varible speed pump, 2hp varible speed sheer descent pump, 520 clean an clear cartridge filter, letro legend with booster pump, 8ft bench with two 3ft sheer decents, 3 Pentair Magic Flow Laminar Jets, Intellibrite 5g led lighting, Build currently in progress
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    I'll do some comparison pictures of the size. I looked at their display and it's huge? Has anyone heard of Mighty Son/asahi pools? That's the brand.
    TF100 Test Kit
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    You said a second return would be better also, is that required? Or could I get away with one?
    TF100 Test Kit
