Thread: Liner failure Procudures
    Jun 2011
    Eastern Pennsylvania
    3
    Hi Guys,
    Well looks like its time for a new liner, my wife and i installed this one back in 1995 so its reached the end of its life.(cant complain). I have a long split in the deep end that if feel is not worth the effort if even possible due to the age of the liner. My questions are should i go ahead and drain it with a pump or just let it drain by itself? Also is it ok to remove the old liner before the new one comes so i can prep the bottom, Pool bottom is vermiculite and portland cement so it is porous. Is it ok to expose it to the elements. What would be a good procedure to follow? Thanks ..
    20 x 40 inground pool, 30K gal, vinyl liner, 1.5 HP Hayward Superpump, Hayward Pro Serier Top Mount S244T sand filter (300lbs sand) with 62GPM design flow fate, Polaris 380 Pool cleaner
    Re: Liner failure Procudures
    It is alright to drain it completely as long as the local water table is below the bottom of the deep end. The simplest thing to do is to let it drain on it's own, and it will stop when it reaches the water table. The big thing to avoid is lots of ground water moving through the empty pool. Often ground water just sits there, which is alright. But an underground stream washing through can create problems, and the same with a high water table that you are constantly pumping out.
    It is alright to expose the pool-crete below the liner. Keep in mind that any debris that gets in will need to be removed, so you normally only leave it exposed for a week or so, to prevent too much debris from accumulating. Typically you need to fully empty the pool to get proper measurements for the replacement liner.
    Jun 2011
    3
    Thanks Jason for the quick reply and wonderful website. So I will let it drain on its own as you stated and then measure for a new liner. Once the liner is on its way I will remove the old one and patch where needed. If any problems come up i am sure to be back with more questions thanks again. Lou..
