However, what you report seeing is completely different. You are measuring the expected FC a couple of hours after adding it (I assume this is after good circulation), but 24 hours later you have more FC with 8.25%. That makes no sense whatsoever. Once in the pool, the life of chlorine has nothing to do with its initial concentration. Yes, the warmer water temperature is very likely the reason the chlorine had more 24-hour loss. Roughly speaking, the chlorine reaction rates double every 13ºF so with a 5ºF increase in temperature the chlorine could get used up reacting with what is in the pool (or with a pool cover) 30% faster.
Last night I had 3ppm. I lowered my PH from 7.8 to about 7.5 and about 30 min later added 64oz of 8.25% Today was hot and sunny all day. No clouds and no shade at all. Now, 24hr later - 4.5 ppm. How could I lose only 0.5ppm in 24 hours? (cya 35-40. 22-23k gallons. everything is in range)
I did not test for FC after adding this Clorox yesterday, is there a chance the concentration is higher than 8.25% (on label)?
How does different PH affect chlorine usage? Will chlorine be consumed a lot less when PH is 7.2-7.4 vs 7.8?
With 64oz of 12.5% I never had more than 3.5 ppm after 24 hours and some times I'd even have about 2-2.5 ppm
The temperatures are cooler now than in June-July when I used 12.5%, but still, loosing .5ppm when it's 85 outside and water temperature around 76(maybe more after today) just sounds unreal
The water is crystal clear.
Thanks
P.S. I have not used any products containing CYA in more than 2 months now, unless this Clorox has stabilizer in it (I could swear liquid shock target used to carry a few years back had stabilizer in it, but may be I was seeing things)
Also, my Clorox is HE, if that could affect the chlorine usage in any way. I have not had any foaming with it, not even when I added 2 bottles (128oz) at once
