Thread: installation question(s)
    Mar 2014
    United States
    10
    Hello all,
    Im about to start a install of a gently used 24' above ground Im just going to give a full run down of my plan of action if you folks could please provide some input as to problems that I could encounter....
    I plan to sink the pool approx 19" so it will be level with my existing deck the hole will be dug 27' around so I have plenty of room to work. The pool is 52" tall my one question on the excavation should I dig 2 additional inches and then fill back in with 2 inches of sand? or just dig the 19" then put the 2" of sand and compact? I will be using cap block on my uprights for support. from there I will be using an armor shield pad and wall foam under my newly purchased J-hook liner. For the filter I will be using a 2 speed 3/4 hp pump but it will be 35' from the pool itself using 1.5" PVC I have a digital timer for it as well ( How long should I run the pump per day?) I will also be using a sand filter for now but may upgrade to a DE and am going to try the saltron retro salt generator it seems to have good reviews. We are scheduled to start digging on 4/5 so Im trying to get my ducks in a row.
    Thanks for the help
    Re: installation question(s)
    Welcome to TFP!
    Ideally you want to dig about 3" too deep, then add 2" of 3/4" minus crusher run to provide a stable base, and one inch of sand on top of that. In any case not more than 1" of sand, or it will tend to shift.
    Mar 2014
    United States
    10
    I have carolina clay for dirt do you think I still need the c&r? Does the inside of the rail need to be deeper for the base or should the entire hole be equal depth?
    Thanks again
