Results 1 to 7 of 7
Thread: Newbi!
    Mar 2014
    PA
    25
    Newbi!
    Hello, I got a new inground, indoor vinyl pool with a handy SWG, sand filter and pump. Also pool is heated.
    I just tested my pool and the numbers are below...
    FCL = HI
    ECL = HI
    pH = HI
    ALY = 23
    CH = 240
    CYA = 22
    The HI readings I am assuming are because my digital meter was off the chart. What should I do? Should I lower the SWG?
    Thanks
    The size of your pool in gallons - 10800
    Pool Type - IG Vinyl
    The type of filter you have - Sand
    Date of pool build/install - 2013
    Jandy SWG, Hayward Gas Heater
    Feb 2012
    Phoenix, AZ
    728
    Re: Newbi!
    To test FCL and practice the methods preached here at TFP, you want to use a FAS-DPD test. Like in the TF-100 or Taylor K-2006 kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Newbi!
    HI HI HI Nolan!
    We really need some numbers on those to help you out. What sort of kit are you using?
    Essential Links:
    Mar 2014
    PA
    25
    Re: Newbi!
    I am using this kit...
    LaMotte 2056 ColorQ Pro 7 Digital Pool Water Test Kit
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Newbi!
    Quote Originally Posted by nolan1123 View Post
    Thanks
    Get a GOOD test kit. I prefer the TF-100, it has everything I need (I also ordered the Taylor 1776 salt test) and with the optional speed stirrer testing is a breeze. I trust my results and know they're accurate.
    Mar 2014
    PA
    25
    Re: Newbi!
    Quote Originally Posted by YippeeSkippy View Post
    The test kit I bought I thought was good. It has very good reviews all over google.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: Newbi!
    i spent a couple of hundred bucks on digital pool tester
    only thing it got close was salt
    in the bin it went
    now using taylor T-2006
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
