Results 1 to 13 of 13
Thread: taylor speedstir question
    delirium330's Avatar
    Dec 2013
    Sacramento, CA
    104
    I just got a Taylor SpeedStir last week and have been enjoying it so far. Iím currently using the Taylor included vial and stir bar that came with the SpeedStir itself to do my daily chlorine testing. I know the TF-100 kit specifically has a vial for only chlorine and Iím curious if I should only use the Taylor vial for chlorine as well?
    I think my TF-100 vials will fit on the SpeedStir just fine and I also think the stir bar will fit in the TF-100 vials, so if having multiple vials to keep the chlorine tests separate from the other tests isnít a problem, is it a problem to be using the same Taylor stir bar for those other tests?
    Built 2003, 14k Gallons, IG Pebbletec, Primary Pump: Sta-Rite Intellipro VS, Sta-Rite Series 3 S8M150 Cartridge Filter, Fiberstars Jazz Light w/Color Wheel, Polaris 280 Vacuum (Runs Zodiac PB4-60 Booster Pump) and 2 Waterfalls (Run on separate, dedicated 1HP Sta-Rite Max-E-Glas II Pump).
    22,553
    Re: taylor speedstir question
    It isn't a problem either way.
    I use the Taylor vial for all my tests but have used the TF-100 vial as well.
    The reason for the separate "Chlorine" test vial is that after a while the FAS-DPD test tends to turn the vial dark. However, it's easily cleaned so I don't worry about it.
    24' x 52" Round AGP. 2hp/ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Dec 2013
    Sacramento, CA
    104
    great thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    The CYA mixing bottle fits on the speedstir, too!
    I hunted down some more stirbars on eBay so I can run every test before I have to wash any dishes.
    Dec 2013
    Sacramento, CA
    104
    I like that idea, the SpeedStir's efficiency is still somewhat weakened by the fact that you only have one stir bar to work with. Did you buy Taylor brand stir bars or something generic that does the same thing?
    Jan 2013
    Houston, TX
    1,079
    Great idea!
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Richard320's Avatar
    Jan 2010
    19,050
    Quote Originally Posted by delirium330 View Post
    Generic 8mm * 25 mm.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    And you put a stirbar in it to mix the Cya solution?
    Essential Links:
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I've rearranged my TF-100 box a little so that each test is within its own compartment and everything flows in order for me. The speed stir stores right in the bottom of the box too. So to speed things up even more I ordered an extra magnetic "bean" and keep one in each vial ready to go. I use the two vials that came with the kit because I find the one that came with the speedstir difficult to read. It all works for me and testing is fast and easy.
    Richard320's Avatar
    Jan 2010
    19,050
    Quote Originally Posted by Brushpup View Post
    Absolutely. Half pool water, half reagent, drop the stir bar in and let it rip.
    It comes out easy enough with a little shaking when the mixing bottle needs rinsing.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by YippeeSkippy View Post
    I've done a little of that too. Whatever works better I say.
    Ok Cool. I figured it would be hard to get out. Skippy's post above reminds me that somewhere there is a thread where people posted pics of their test rig. You may have started it Richard, can't remember.
    Essential Links:
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    http://www.troublefreepool.com/threa...ture-of-TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Wow, you are good Mr. Leebo! Thank you Sir, that is the one I meant. I will be bumping it for sure.
    Perhaps I will wait until I am actually testing with some of my new pool water in the background...
    Essential Links:
