Thread: Nature 2 soft fusion saltwater system
    May 2013
    Ocean County NJ
    183
    Hello everyone, My pb was suppose to install an aquapure saltwater system and when I went to inspect I noticed a nature 2 fusion saltwater/mineral combo system. I told him I want it out due to negative reviews, He said that it does what a saltwater system does and 2nd feature mineral aspect. He said can be used without mineral cartridge. I am deciding wherther to have him replace with aqua pure or just leave alone. Is the aquapure a superior system? Or are they basically the same in terms of saltwater element.
    I know that many say problems are with staining, on manufacturers site says guarantees against staining due to minimal mineral releasing.
    Thanks for input!
    Re: Nature 2 soft fusion saltwater system
    The soft fusion units generally include a SWG that is slightly smaller in size than an equivalent from AquaPure. Otherwise it is similar when used without a mineral cartridge. We strongly recommend avoiding the mineral cartridges.
    May 2013
    Ocean County NJ
    183
    Thank you Jason for reply.
    Freeform gunite, 14,000 gallon saltwater sport pool.
    10 ton moss rock w/ waterfall, 50 sq ft raised spa.
    Bluestone coping, pebblesheen. Jandy pro flo 1 hp pump, legacy 325k heater.
    38,285
    Also not sure it is that easy to use without a mineral pack because you need the canister to seal the system.
    Oct 2011
    West Monroe, LA
    12
    Tell your PB to take out the combo if it is not too late. Otherwise, we had to cut the top off of the mineral cartridge to use to seal off the mineral cartridge side of the combo.
    18500 Gallon 17x34 gunite pool
    Jandy Stealth Pool Pump, Cartridge Filter SWG
    May 2013
    Ocean County NJ
    183
    Thank you everyone for replies
