Results 1 to 16 of 16
Thread: SWG Plumbing head-scratcher, need advice on how to tackle this
    I am getting everything ready to install my SWG, but I have a plumbing issue that I'm not certain how to tackle.
    Here is a picture of where I was planning to transplant my existing chlorine dispenser (c'est la vis!)
    Here is where i'm not sure what to do aside from cutting out the multiflow thingie:
    This is more doable as I have some pipe to work with
    Or just remove everything starting from the left of the dispenser to these two pipes and cut them out:
    Brian, Pool newbie in Atlanta, GA. 24k IG vinyl pool, Circupool SI-45 SWG (purchased 3/2014) , Hayward Pro Series Sand filter S220T, Pentair 1hp 2-speed superflow (thanks Jbizzle!), TF-100 test kit w/ SpeedStir
    Removed -> Hayward 1HP Super pump SP-1607-Z1-M
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: SWG Plumbing head-scratcher, need advice on how to tackle this
    I think you could install the SWG vertically in the space you have without cutting out the valve. See this web page: http://circupool.mybigcommerce.com/c...tallation-kit/
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    I thought about this, but the issue is the removal of the Dispenser without making cuts. Thats the crux I think
    Most three way valves can accept two pipe sizes, one going inside, as yours is, and the larger side fitting over the outside of the connection. Thus, you could cut off the connection on the chlorinator side of the three way valve, and use a larger pipe size with a reducer almost right away,
    Thats brilliant actually!
    Is this what you mean Jason?
    http://www.homedepot.com/p/NIBCO-2-i...2112/100346360
    I wonder if it makes sense to keep the dispenser at all...im actually now thinking (since the screw in fittings into the dispenser are loose...meaning I can rotate the entire canaster up and down) to cut it here:
    So looking at that pic from sargent, I went to home depot and laid this out, I went with the "sweeping 90 elbows" as I've heard that would be better for overall performance.
    What do you guys think?
    oops double post
    Quote Originally Posted by rarenomad View Post
    Thats brilliant actually Jason!
    Is this what you mean?
    Yes, just measure the valve to make sure it is 1.5 and 2" instead of 2" and 2.5". You will also need a short segment of 2" pipe between the valve and the reducer.
    Ah gotcha. The last part is a problem though. There isn't any pipe between the valve and the dispenser
    Jul 2012
    Saugerties, NY
    447
    If you don't care about the saving the old chlorinator, I would say cut the chlorinator on the right side, and spin off the remaining piece. Then you can just thread on an adapter to that side. The other side you have some room to work with if you just cut it off, and if you need even more room, you can cut it off at the vertical pipe coming off the filter.
    TreeFiter
    Pool Technician
    Saugerties, NY
    The short piece of 2" pipe will fit over the end of the three way valve at one end, after you cut off the fitting currently connected to the 3 way valve, and the other end will connect to the reducer.
    {EDIT}This is wrong, a standard 2" fitting will fit the outside of the valve, not a 2" pipe, see below.{/EDIT}
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    In your picture you have elbows that are meant for waste-water pipe, non-pressurized. You need fittings that are designed to take pressure. What Jason was talking about for the three way valve is that it looks like there is a 1-1/2 inch pipe slipped into the valve. You need to cut that off and slip a 2 inch pipe over the valve. Then you can get a bushing to reduce the pipe size to 1-1/2 inch.
    This elbow over the valve: http://www.homedepot.com/p/Mueller-S...6Z5yc1vZ25ecod
    This bushing to reduce to 1-1/2 inch: http://www.homedepot.com/p/Mueller-S...vZbuu6Z1z114x9
    This for your other (1-1/2 inch) elbows: http://www.homedepot.com/p/Mueller-S...6Z5yc1vZ25ecod
    Wait a tick...it can't be that easy... (runs off to check )
    38,298
    I think Jason is mistaken. The OD of a larger pipe will match the outside diameter of the valve, you then use a coupler to attach then.
    In reality you could just use a larger coupler and then a reducer in the coupler back to your normal pipe size.
    Also I agree avoid using non-schedule 40 fittings like those sweep 90s.
    jblizzle is correct, I explained it wrong. A standard 2" 45 degree fitting (or other fitting as needed) will connect directly to the outside of the valve, not a 2" pipe. You may still need a bit of 2" pipe for connecting the other end of that fitting to the reducer.
    Ok so I'll change out to the schedule 40 elbows tomorrow, I do have two 2" to 1-1/2" bushings that fit right into a 2" coupling I have. So would that mean I could connect that bushing adaptor directly to the elbow?
    Just to confirm, I need to get a 2" elbow and that will connect to the valve?
    38,298
    Correct.
