Results 1 to 7 of 7
Thread: What to tweak?
    Mar 2014
    Orlando, FL
    35
    What to tweak?
    I've been taking care of my chemistry for about 2 months now. I've been in the process of lowering my overall TA, it was at 150. Using TF-100 for testing.
    New Results (3/23)
    - FC 6.5
    - CC 0.0
    - PH 7.5
    - CH 300
    - CYA 50
    - TA 90
    Is there anything that should be tweaked? I have the SWG running at 10%.
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    Re: What to tweak?
    There are only minor points, tweaking is right. When using a SWG the recommended CYA level is between 70 and 80. Your FC level is also a little higher than it needs to be with a SWG, especially given your current CYA level. Long term you will want to lower TA a little more, but no obvious reason to rush on that.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Re: What to tweak?
    If the waters clear, tweak the amount of cold beverages currently in the refrigerator. There's too many in there, and some should be consumed quickly, while relaxing by the water.
    Numbers all look good to me.
    Mar 2014
    Orlando, FL
    35
    Re: What to tweak?
    @Leebo - Thanks -- I'll drink one for ya!
    @Jason -- I've thought about not running the pump as long to reduce the FC levels -- I currently run it for 6 hours -- mainly because we like the ambiance of it running. I suppose I could tweak it back to 4 hours. I have the SWG on the lowest setting. I'll get the CYA up a bit and keep working on the TA. Whats the optimal TA level? 80?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: What to tweak?
    Optimal is whatever YOUR particular pool likes to maintain a more or less stable PH. Could be anywhere from 60 to 80 in most cases.
    30,404
    Re: What to tweak?
    Because your SWG is only running 10%, I think I would simply leave everything alone.
    Test your chemistry as you swing into the pool season and I think you'll have a great summer. Very nice work.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: What to tweak?
    I'm sorry, but Leebo offers the very best advice I see here.
    Those numbers look pretty nice!
    Essential Links:
