Thread: What are my chlorine options?
    Jan 2014
    Henderson, NV
    6
    Not to hijack, but since its related....
    You were hijacking, so I moved your post to a new topic. JasonLion
    We occasionally go away for a long weekend (3-4 days) and I just started using liquid clorine over tabs/feeder, based on input from the experts here. Since I have a very small spool, I would prefer not to use tabs, as I can see a CYA change after only a day or two.
    What are my options? Given such a small size (~2600 gal), I think a salt system may be overkill, or maybe not. Also, are there auto chlorine dispensers that are cost effective for such a small pool? I dont care if I eliminated the daily manual add and replaced with an automatic system, just not sure where to start to look for a solution, or if would not make sense, cost wise.
    I would budget up to $500-600.00 for something if its worthwhile....maybe more.
    We live in Vegas and heat and use the spool year round, 1-2 times/week in winter, 4-6 times/week in warmer months. I do plan to drain and refill each spring, if that means anything on a solution.
    2600 gal spool, IG fiberglass
    Pentair CC-150 cartridge filter
    Pentair IntelliFlo VS pump
    Pentair MasterTemp 250HDNA heater, with cupro-nickle exchanger
    2x swim jets
    38,483
    Re: Automatic Feeder Chlorine 'Types'
    I would think a small SWG would be way under that price. Maybe the Intex SWG or similar AG pool SWG.
    Edit: a quick look puts the Intex SWG under $150 at Walmart.
    Jun 2012
    Howell, NJ
    977
    Amazon has the Intex SWG for $138.24, with free shipping. If you do go with the Intex, you just have to remember to disconnect the copper bars. There's posts on here about how to do that. http://www.amazon.com/Intex-Krystal-...ntex+saltwater
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
