Results 1 to 8 of 8
Thread: High TA
    High TA
    I just tested my pool and my TA is 190. Is that to high for a vinyl pool, 20,000 gallons. No other problems. Pool is crystal clear. I recently added absorbic acid to try to get rid of stains on my step, which didn't work. I was wondering if this would raise my TA. Do I need to worry about the 190 or is is OK? By, the way I just started using BBB this year and I am thrilled. This is the best my pool has ever looked. Thanks for all the help
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    30,403
    Re: High TA
    Renee,
    Welcome. TA of 190 is a little bit high but whether it will cause harm depends on your other test results for pH and CH. Could you post those, please?
    Re: High TA
    Sorry, Here are all my test results from today.
    FC 2
    CC .5
    TC 2.5
    PH 7.2
    TA 190
    CH 110
    CYA 35
    Thanks for your help.
    Don
    SW Florida
    Pentair SWG
    30,403
    Re: High TA
    Renee, I think you will be fine with that TA. If your pH was up around 7.8 or 8.0 and your CH was up around 400, that could cause some scaling problems but your numbers are ideal to prevent scaling so I wouldn't worry about it.
    Check your pH every 3-5 days for a few weeks. If your pH is rising up rather quickly (say it's at 7.8 in a week) then I would consider bringing TA down to around 100 or so. If your pH is pretty steady, I'd leave everything alone.
    Jun 2008
    Thornton, PA
    76
    Re: High TA
    Help me understand that first statement please? She indicated that she has a vinyl pool -if I read correctly. What is it that is supposed to scale? I gather that vinyl pools do not scale but could other things? Pump, lines, filters?
    I'd really like to know please.
    Dan
    28K Gal. 802 Sq Ft., Free Form, IG, Gunnite with Midnight Maui Hydrazzo Carlton Pool. Exposed Aggregate Decking. Jandy DE Filter, 1.5 HP Jandy Pump, SWCG. Zodiac 380 pressure-side cleaner. Completed Construction: May 2008.
    Guest
    Re: High TA
    scale deposits can occur in ANY type of pool if the calcium, TA,and pH are high.
    Jun 2008
    Thornton, PA
    76
    Re: High TA
    So calcium scale forms on vinyl then?
    Interested.
    Dan
    Guest
    Re: High TA
    Quote Originally Posted by dfiletti
    Interested.
    Dan
    it certainly can if water conditions are right for it to form. Calcium is a metal and scale is just a form of metal 'staining'. Vinyl pools are not immune to metal stains and scale deposits.
