Results 1 to 9 of 9
Thread: Can you put an above ground pool in the hole of an inground, indoor pool?
    Mar 2014
    Illinois
    1
    I have a unique question. We have an indoor, in-ground, 20X40, 3ft to 10ft deep pool that was probably built in the 70's. We filled with water last year but after 3-4 weeks, it ran dry. In brain-storming ideas, is it possible to fill the deep end with mason sand to level it, and install an above ground pool (which would relatively be sunken into the ground) into the hole that is already there? We would then do the cosmetics to complete it. HELP!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Very neat idea. It might just work. First you would need a pool that is rated for burial. Warranty reasons I would think. As you said fill in the deep end and level it with the shallow end. Instead of sand which doesn't compact very well, you could use screenings from a quarry which does compact well. You would have to put it in 1ft lifts or so and compact each lift until you get level. Maybe a couple inches over the shallow end also so the liner isn't on the pool floor. You could use the same material to back fill around the pool then.
    I take it, it would be an oval pool ? I'm not sure my idea would work. Just throwing something out there. Let's see if anybody else has some ideas. 😎
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Can you put an above ground pool in the hole of an inground, indoor pool?
    It may be a lot cheaper and more eye pleasing to fix and keep what sounds like a nice big pool. Have you had it leak checked by anyone? Is it concrete/vinyl lined or what? Welcome to the forum.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    I suppose you could, but I agree with woody on having it checked out. Just picturing what you are describing doesn't sound so good in terms of looks.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I feel anything is possible with imagination and a well thought out plan. What's pleasing to the eye for one person is different for another. This idea might go against the grain but that's ok. Just my 0.02. 😎
    Jeff
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    What about a liner custom made for the original pool?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    There ya go. Good idea !! 👍 Thinking outside of the box. I like that. 😎
    Jeff
    AlanH's Avatar
    Jul 2010
    Nicaragua
    54
    Bomber - welcome to TFP.
    Thinking outside the box, doing something different, is certainly something I did on my build so if it works for you go for it. Whichever option, one thing really hit me, and maybe you have thought of it. Where did 40,000+ gallons (assuming an avg depth of 7.5ft) go in just 3-4 weeks and what did it do on the way. Before doing anything (and maybe woody was getting at this too) it may be a good idea to have the existing pool vessel and surrounding area inspected for voids, wash-outs, sink holes, or similar. Good luck.
    "I took the road less traveled by, and that has made all the difference." (R. Frost); 12.5K gal; 18'x72" round joined to 10x16x18" oval; vinyl liners; ferrocement-like wall panels; perimeter wet edge; fountain and cascade; Pentair Dynamo 1hp 2 spd; Pentair CC75 filter; Pentair no-lube valves. My build here.
    Casey's Avatar
    SW PA
    10,438
    Well, any resolution to this? What are you going to do with this pool?
