Thread: Water Circulation
    Water Circulation
    Here is my problem: My 25,000 pool has only 1 skimmer and 1 in ground filter in the attached spa. It has 2 returns to the pool, and 2 in the spa. The main drain has been blocked because of a leak(my landlords idea) I have no way of filtering water in my deep end. I have read that the skimmer only filters 12 inches of the top water. My 2 returns for the pool are located on one side closer to the shallow end of the pool.
    What is a good way to get all of my pool water to start filtering? Is that even possible with just a skimmer and 2 returns in the pool?
    I forgot to mention this is a free-form pool, i guess shaped like a kidney?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Water Circulation
    Aim the eyeballs down. Or at least the one closest to the deep end.
    A wall whale brush will also move water like you wouldn't believe.
    Seriously -- start at the wall closest to you and push it out to the end of your reach, wait a couple seconds, and watch the wave erupt against the opposite wall.
    Okay I will look for one of them. Thanks for the suggestion.
    Aiming one of the returns down towards the bottom of the deep end is usually very effective.
