Results 1 to 10 of 10
Thread: BBB Progress... 7 weeks in
    I had my liner replaced the end of April and officially started BBB the second week of May. Below is an overview of my progress thus far. You can see my TA is steadily dropping and CYA is almost where I want it. My pool could not look better!
    PS.. I didn't record it, however, my I tool my first CH reading yesterday. Result was 200.
    Notes:
    - I add CYA via a sock in the skimmer. Only a few lbs at a time.
    - LC is Clorox which I pour slowly over the return in the deep end
    - I also add MA over the return in the deep end
    - I use skimmer socks
    - I am still using chlorine tabs until my CYA is where I want it
    I assume I could have been move aggressive with dropping pH with MA. I just decided to take it slow. I think I am on my 4th gallon now!
    Thanks so much everyone!
    2003 Marquis Euphoria - 400gal
    Mar 2008
    Central VA
    328
    Re: BBB Progress... 7 weeks in
    Wow, nice chart!
    So far I've scribbled my test results on notebook paper, which invariably gets damp by the time I'm done
    Good job, there, you can really see your progress...I went to BBB in mid(?) April, and my CYA is finally close to where it needs to be with the SWG. I am still wrestling with TA, but finally got it down to 90 this last weekend.
    It's fun, isn't it? I kind of like being the mad chemist. muhahaha
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Thanks. It has been quite the journey!
    Mar 2008
    Garden State
    80
    I created a very similar spreadsheet so I could track what my levels were and what I was adding. I had thought about building formulas into it so it would calcuates what I should add, etc. but just haven't done that yet.
    Maybe I am confused , however I believe you have your columns mis-lableled. Isn't TC the combination of FC and CC? It looks like you have FC as the combination of TC and CC (I think FC and TC are swapped on your columns).
    Pool Details:
    - inground vinyl liner, approx 35,000 gal; Hayward DE-6000; Pentair VS3050
    - 600sq ft Heliocol; Blue Diamond; 8 Gal Liquidator
    - TF-100
    Good catch.. The columns are correct.. I just suck at reading the TC test. Now that I think about it, is the TC test even necessary since the FC+CC always equals TC?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If you can test for FC and CC that's all that matters in my book.
    Ok.. so the small blue kit is only really needed for pH test?
    Mar 2008
    Garden State
    80
    That's all I use mine for.
    If your CL level is below 5 (as yours is, mine needs to be higher due to higher CYA level) you could use that CL test as a daily test and just use the other one on a less frequent basis.
    Pool Details:
    - TF-100
    11,969
    Quote Originally Posted by pooltime
    I should have clarified....I do use the blue kit, I use the oto test for daily testing and making sure my chlorine is about 5-6. But I'm really guessing with it, as I have a hard time with the darker shades of yellow. So I use the FC/cc test once a week or as needed, not very often.
    Excellent, thanks!
