Thread: Intex Ultra Frame Skimmer Bracket
    Mar 2014
    Indiana
    1
    I am in need of a skimmer bracket for a Intex Ultra Frame Pool. Currently all i can find is for the metal quick set from. Can anyone direct me to where i might be able to get one. Thanks
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex Ultra Frame Skimmer Bracket
    How about installing a through the wall skimmer? It has been done many times by others here on the forums. The only caveats are the adapter you will have to make, and cutting a hole in the side of the pool.
    Search the forums for how others have done this.
    I suggest this because the Intex brackets won't last more than 1 season, and for the ultraframe, you would have to buy the entire skimmer assembly, I think. I've not seen those sold separately anywhere.
    Orlando, FL
    690
    It's not much cheaper than buying the entire thing. Mine broke right in the curve of the arm. I used tie wraps to secure it to the pool and it lasted forever. See if there is a way you can "rig" it. Otherwise, here it is:http://www.amazon.com/s/ref=nb_sb_no...kimmer+bracket
    and here: http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
