Thread: How to setup a Valve Actuator on a Pentair ET4
    smallwoodst
    Guest
    Help please. How do you use an aux button without using a relay.
    I have an ET4 and want to use valve to turn on valve for my Polaris 360. I don't want to use up a relay circuit if possible but do want to be able to use control button to activate cleaner valve.
    any help would be very much appreciated.
    I did install everything my self
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: How to setup a Valve Actuator on a Pentair ET4
    Assuming you already have cleaner assigned and labeled.
    MENU/SETTINGS/CIRCUIT FUNC./Scroll to cleaner, select/scroll to valve, select.
    You must also:
    MENU/SETTINGS/VALVES/B:/ scroll to cleaner, select.
    Don't forget to plug the actuator into the valve "B" socket on the board. You want to use valve B as valve A is reserved for solar either now or later date.
    Factory Warranty Station for:
