Thread: testing ph??
    testing ph??
    when i test for ph i get a 7.2 however, when i let the test sit for about 5 or 10 minutes it goes above8.2. which is correct, the test when you do it at the spot or the 5-10 minutes wait? i am getting confused with it.
    18' 52" deep laguna agp with pentair 1 1/2 hp pump and 22" filter, intex swg
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: testing ph??
    On the spot, I believe. If I'm wrong the guru's will be along to correct us
    Guest
    Re: testing ph??
    read the pH test when you first do it. Are you testing with strips or drops because what you describe is usually seen with the strips.
    Re: testing ph??
    i'm using the taylor k-2006 drops
