Thread: Quick question about CH
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Hy Guys,
    I have a vinyl pool. I've read here not to worry about the CH but Pool Calculator suggest I add 383 oz of calcium chloride. Is this necessary w a vinyl pool?
    FC 7.5
    CC 0
    PH 7.6
    TA 100
    CH 150
    CYA 55 and falling
    and, how do my numbers look?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    38,392
    Re: Quick question about CH
    PoolMath (or the old Pool Calculator) only tell you what to add based on what YOU set as the Now and the Target values. If it said that you should add CH, it is because you put a Target CH value in that was greater than your Now CH value.
    You do not need to worry about CH with a vinyl liner. Everything else looks fine.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Awesome! I keep thinking the column on the right is the recommended level and that's what I need to be at. I love this forum!
    Montgomery, AL
    Isaac-1's Avatar
    SW Louisiana
    6,711
    have you set the pool math targets for a vinyl pool and using TFP method?
    ooops looks like we may have a bug in pool math for CH levels in vinyl pools
    38,392
    Quote Originally Posted by Isaac-1 View Post
    What bug? It says 50-300 which is reasonable (for TFP recommendations)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes but auto fills in 260 when vinyl pool is selected for pool type
