Best material for replacing pool tiles
Jul 25, 2010
201
Folks,
Any particular favorite adhesives / cements for tile replacement? I have 3 small tiles that have fallen off the pool side, above the water line. We've had a very cold winter by Houston standards, not sure if that has had anything to do with it. I'm sure I can pick something up from Amazon that will do the trick, but am never too proud to ask and learn even with a small job like this one.
Thanks in advance.
A thin-set mortar should work for you. Preferably, one rated for use under water such as these:
http://www.laticrete.com/Portals/0/datasheets/lds6770.pdf
http://www.custombuildingproducts.c...fied-thin-set-mortars/tile-repair-mortar.aspx
http://www.ardexamericas.com/en-us/Products/tilestone/Pages/X77.aspx
Any thin-set mortar will probably work well enough if you can't find a product such as the ones above. It's probably not worthwhile to track down a special thin set for just a few tiles. Try to get a mortar that matches the grout you will use.
Thanks James, I appreciate the response. I'll follow up.
Thanks
