Thread: Best material for replacing pool tiles
    Folks,
    Any particular favorite adhesives / cements for tile replacement? I have 3 small tiles that have fallen off the pool side, above the water line. We've had a very cold winter by Houston standards, not sure if that has had anything to do with it. I'm sure I can pick something up from Amazon that will do the trick, but am never too proud to ask and learn even with a small job like this one.
    Thanks in advance.
    Re: Best material for replacing pool tiles
    A thin-set mortar should work for you. Preferably, one rated for use under water such as these:
    http://www.laticrete.com/Portals/0/d...ts/lds6770.pdf
    http://www.custombuildingproducts.co...ir-mortar.aspx
    http://www.ardexamericas.com/en-us/P...Pages/X77.aspx
    Any thin-set mortar will probably work well enough if you can't find a product such as the ones above. It's probably not worthwhile to track down a special thin set for just a few tiles. Try to get a mortar that matches the grout you will use.
    Support the site
    Quote Originally Posted by JamesW View Post
    Thanks James, I appreciate the response. I'll follow up.
    Thanks
