Thread: Hayward Northstar
    Jun 2010
    Central California
    7
    Hayward Northstar
    I have a logistical question. Trying to get my motor out of my pump, however, there is a pipe way too close for me to get the collar that locks the motor into the pump. This is the second motor, so I know it has been done. Would like to avoid calling the pool guy that replaced it last time, since I would like to fix it myself.
    Is there a way to dismantle the motor to get it out of it's trapped space?
    It is a Hayward Northstar pump, currently with a Century Centurion 1.5hp motor
    Thanks for your help!
    Sheri
    15K IG pebble-tek; Hayward Swimclear cartridge filter; Hayward Northstar pump; Century Centurion 1.5HP motor; Ultra Pure Automatic Water Cleaner; Polaris automatic vacuum cleaner; Hayward H series heater
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Hayward Northstar
    Remove the couplings from the inlet and outlet so you can move the entire pump.
    Mark
    Jun 2010
    Central California
    7
    How difficult is it to get these pipes back in place? Looks like I probably will have to remove the one to do my job.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Those are a bit easier than the ones on the pump but I was talking about the ones on the pump itself.
    Mark
    Jun 2010
    Central California
    7
    Got it. Thank you.
