Results 1 to 20 of 20
Thread: Inground Pool Backwash hose
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Last summer, I went through three backwash hoses, two of which burst open the first time I used them. I am looking for something much more sturdy this year - not what is readily available in your local pool stores. Anyone have any suggestions? I have been searching the web, but they all appear to be the same stuff.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: Inground Pool Backwash hose
    Fire hose. Check eBay, your local fire dept for old hoses, or other online sources.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    If you have room, plumb it with hard pipe. Mine is plumbed with ABS out the back yard, works great, drains where it needs to, and is never in the way.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    38,371
    They should only burst if you do not have them laid out straight before you turn on the pump. Or if you have introduced kinks into them. And likely a good idea to store out of the sun.
    There have been previous discussions about fire hoses ... not sure what is required to attach them.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Fire hoses typically have NH/NST threaded fittings in the U.S. although there are other types so look for NH or NST listings (they are interchangable), you typically need an NH or NST to NPT adapter , these are available in polycarbonate or brass for as little as about $10 on ebay. 1.5 inch fire hose is very common (most building hose cabinets use these), and often available in 50 - 100 ft lengths "used" on ebay, these used hoses often spent their whole life never being used in a cabinet and were replaced due to age, by fire code these must be replaced or recertified after a certain age (I think 20 years), so they tend to sell cheap on sites like ebay. Often asking prices / auctions will vary considerably, but you should be able to get one under $50.
    Ike
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Thanks, Isaac-1 - I appreciate the info, but it is greek to me. Don't understand your fitting comment, as I know nothing about fire hoses and fittings. The piece on my sand filter that I attach my discharge hose to is not threaded. I am willing to explore this avenue if I really knew what I was looking at. I have checked ebay and found the hoses but have no idea if they would work for me. I don't understand what size I would need as far as fitting onto the sand filter, etc. I would be most appreciative if you could give me more specific information so that I can pursue this avenue.
    JoshU's Avatar
    New Orleans, LA
    543
    There are some really poor quality backwash hoses out there. Quaker Plastics makes a good hose: http://cardinalsystemsinc.com/produc...ischarge-hose/
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you can take a photo and post it of your discharge fitting we can help tell you what you need. You may have a 1.5 inch NPT to screw in hose barb fitting already screwed into your backwash fitting, or it may be a glued in slip fitting to hose barb.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I have yet to do this, but I believe you can cut the end if the fire hose off (not easy, but not impossible with the right tool), then just use the clamp that probably is already attaching your discharge hose. When my current cheap discharge hose blows, that is my plan.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Firehose ! You people are brilliant ! Haha! I just bought 100 footer on Ebay and also one of those red round with spokes fire hose reels to roll it up on. All for less than 100 dollars.
    I'm stoked! Life is good today!
    Thank you!
    Quote Originally Posted by Isaac-1 View Post
    Ike
    Divin Dave,
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by JoshU View Post
    Any idea where I can buy this?
    I've searched and can't find them for sale.
    Back 10 years or so ago, I didn't have to worry about kinks or unfolding and making sure everything was perfectly laid out. You just hit the button and the house jumped out. Now, they are so thin that they split even when they are brand new. I just through one away today that has only been used once because it split. Also because they were thicker in the past, they didn't kink up and twist near as much.
    I thought you guys were joking about the Fire Hoses but see by the end of the thread you were serious!
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    The firehose works GREAT! No kidding! I just cut teh fitting off the end and use a couple radiator clamps to clamp it to the PVC pipe. It leaks a little around the clamp, but so what?
    It will last for YEARS. One of the best ideas ever.
    Quote Originally Posted by les_garten View Post
    Divin Dave,
    threecheese's Avatar
    Jun 2014
    Long Island, NY
    56
    I've found the Quaker stuff on a few sites:
    Hoses - Pool Maintenance Cleaning - In-Ground Pools/Spas - Pool Plaza
    https://www.poolpartsonline.com/p-52...-flexible.aspx
    30kgal in-ground/steel with vinyl liner, aluminum bullnose coping || 1 H.P. superpump || Polaris P9550 robot|| Hayward 48sq ft DE filter || Taylor K2006 kit
    Sep 2016
    Escondido/CA
    638
    I've recently made one out of shop vac hose. I epoxied a 2" PVC fitting to one end, and it works great, and was cheap. But they don't come very long.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Jun 2014
    Long Island, NY
    56
    Quote Originally Posted by xyz View Post
    Sounds like fun
    I've got a 100+foot run to get from pump to somewhere I can turn into a swamp, and last year I had 3 different hoses fail in multiple spots (that I got at my local chain). All garbage. I created a frankenstein hose with the remnants and some couplers and that started sprouting tiny holes. One of the tiny holes sprayed yellow water 10+ feet to my wife's car, she wasn't pleased
    The hose that came with my house was awesome (likely from the original pool install in the 80s), I am an idiot for throwing it away because it was "old". It was some kind of braided fabric, and it weighed a ton, I would totally buy more of it if I could.
    Mar 2017
    House Springs
    97
    I bought the flat blue hose from Tractor Supply. It is a fiberglas mesh hose with PVC coating. Look for discharge hose. It was .75 a foot
    Pool: 14,000-gal IG
    Filter: Pentair Sand Dollar, Pump: Pentair Superflo VS
    Automation: Pentair EasyTouch w/ Autelis, Lighting:Globrite
    Pentair SWG IC20, Prowler 820, K-2006
    Jul 2015
    Pittsburgh, PA
    98
    We live on a steep hill. The pool is a story above the street. The yard behind the pool is another 10ft higher. Point is backwashing means 100% of the water ends up in the street if I put a hose on the grass anywhere in my yard where it doesn't run back into the pool.
    With that I hard plumbed it into a PVC line that runs behind a retaining wall and straight into the street. Hard plumbing was great. There's nothing to attach and it's fixed. If this is a possibility I'd go this route. You could even dig a dry well with gravel and pump into that. If you aren't backwashing too often it will drain without an issue.
    In-ground 15x30 concrete pool with vinyl liner
    Triton II sand filter, Hayward Pump, Raypak 266 heater
    Rehab thread: Pool rehab, need advice
    Jun 2014
    Long Island, NY
    56
    Quote Originally Posted by ntobik View Post
    Awesome. Dumping pool backwash (or even pool water) into the street/storm sewer here (NY) is illegal. The day I moved into my new house the nice lady next door told me that if I did this, the guy across the street is a snitch and would call the town . It's been a huge PITA. I'd love to dig a drywell to take all of the pain away.
    What I did last year was plumbed a giant 'T' from 1.5inch PVC and drilled 20 or so weep holes into it. I connected it to my multiport valve via a long flexible backwash hose, and laid it in my front lawn, it helped keep it watered. This year I am going to modify it to allow me to take it apart, because it's a pain to fit in the garage. Also thinking about a new version with smaller holes, so the water goes higher like a real sprinkler system.
    Jul 2012
    Basking Ridge, NJ
    46
    Here's an example of one that has poly reinforcing threading in it. Lays flat and takes up same amount of room as the thin plastic ones you see at pool stores.
    http://www.ebay.com/itm/100-Feet-x-1...38.m2548.l4275
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
  20. Back To Top    #20
    Jun 2014
    Long Island, NY
    56
    It looks like the query term to find the really good backwash is "agricultural strength hose", I even found some of it (2") on Amazon for $0.80/ft.
    2" Dia. x 100 ft HydroMaxx® Heavy Duty Lay Flat Discharge and Backwash Hose for Water Transfer Applications. 4 Bar Agricultural Grade Construction.
    https://www.amazon.com/HydroMaxx%C2%.../dp/B00821CE8U
